Go Back   EcoModder Forum > AltModding > Alternative Transportation
Old 04-14-2008, 12:35 PM   #1 (permalink)
jwxr7's Avatar
the metro experience (retired) - '94 geo metro 4 dr HB
90 day: 66.44 mpg (US)
jwxr7's bent build thread
I finally got motivated enough to start building the recumbent that I've talked about making for years. I'm following an EZ-clone design from here http://www.recycledrecumbent.com/. The bike started life as a black colored tall frame schwinn road bike and a white colored Belgium made Trak (not Trek) road bike that used knit style tires. I've pretty much finished fabbing the frame at this point. The bare frame weighs in at around 8lbs 8 oz. The schwinn was a pretty heavy frame. I still have a long ways to go before I can test ride it. The seat will be my biggest challenge. Here are some pics of the frame as I was finishing the rear triangle alignment and then adding the 2 bottom rails. All that's left for major frame work is to finish closing the joints for the bottom rails to rear triangle and bottom rails to crank mounts then weld em up.
Edit: I'm not a bike expert and I don't know all the proper nomenclature for bikes and thier parts so bear with me.
ID:	576   Click image for larger version
ID:	577   Click image for larger version
ID:	578   Click image for larger version
Best tank= 81.23 mpg on 07-01-2008
Longest range= 791 miles on 9.74 gallons
Old 04-14-2008, 01:26 PM   #2 (permalink)
MechE
The Miata - '01 Mazda MX-5 Miata
Cool
Have ridden 'bents before?
Cars have not created a new problem. They merely made more urgent the necessity to solve existing ones.
Old 04-14-2008, 01:41 PM   #3 (permalink)
jwxr7's Avatar
Thanks,
Years ago I rode around on a home brew delta style trike recumbent that i owned for a while. It was very very heavy and only had one speed but was fun for around town cruising. It definitely takes different muscles to move around on but the riding position is nice. My neck and wrists don't agree with long traditional road bike rides anymore and I'm hoping this will keep me riding more.
Old 04-14-2008, 01:59 PM   #4 (permalink)
jwxr7's Avatar
I'm finishing the welding on the bottom rails today. I strayed from the plan a little on the rails. They call for two 3/4" emt rails and there is a slight bend near the rear, but I only owned a 1/2" emt bender so I used 1/2". I hope it's strong enough. Over the weekend I went to a local barn sale and found 3 different types of 3/4" pipe and emt benders (shown in pic to the left of the 1/2" one) for $5 each so I bought all of them . Now I can redo it with 3/4" if i have to .
Old 04-14-2008, 02:06 PM   #5 (permalink)
pontiac trans am - '00 pontiac firebird trans am
jeep 1 - '02 jeep wrangler
90 day: 16.76 mpg (US)
jeep 2 - '07 jeep wrangler x
90 day: 19.39 mpg (US)
Toyota - '09 Toyota Corolla lx
looks like a great project, im working on designing and building a recumbent trike.
have fun with your project and have many safe miles of riding
Old 04-14-2008, 04:54 PM   #6 (permalink)
jwxr7's Avatar
thanks john,
I finished welding the frame, now onto all the parts that go on it.
I know I should try working on the seat but I don't want to get bogged down this early on something hard.
Next day I plan to weld a brake bridge to the front fork since I'm using a 20" wheel. Then clean up the old head tube bearings and install it.
Then clean up the crank bearings and install bottom bracket and crank arms. I've got my eye on a 3 ring "biopace" crank a friend has on an old specialized mountain bike, but I just want to get it road worthy first then upgrade components if it's worth the effort. Maybe put the rear wheel on and a kick stand so it looks like it could roll .
Old 04-14-2008, 08:45 PM   #7 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Subscribed. Looks good so far. Nice find - all those EMT benders!
And... whose MG is that?
Old 04-15-2008, 08:05 AM   #8 (permalink)
jwxr7's Avatar
Thanks,
That's my boss' MG. I decided to build the frame at work since I dont have a large flat work space in my barn at the moment.
Old 04-15-2008, 03:23 PM   #9 (permalink)
jwxr7's Avatar
got the head tube bearings cleaned, regreased and installed. Also did the same with the crank bearings.
Ran into a little problem with the bottom bracket though. I am using the crank and bottom bracket off a different schwinn because the original that was on the Trak was the old heavy pinned style. The tube that houses the bottom bracket must be a bit wider than the one on the schwinn because by the time I snug up the bearings properly there are only like a thread or two sticking out on the left bearing cup to allow the jam nut to thread on. Not sure what i will do about that. I could mill the face of either side to narrow the tube, but that would be a mess to try setting up properly with the long frame and all.
Old 04-16-2008, 12:03 PM   #10 (permalink)
jwxr7's Avatar
I think I'll get by with the little amount of threads for the bottom bracket bearing cup jamnut for now.
I put the wheels, crank, and kickstand on and weighed it. It was 23.74lbs as shown in the pic below. Over 6lbs of it is from the steel rear wheel/tire assembly . I can upgrade to lighter stuff after I prove out the design, my goal is to be around 35lbs when done.
Ben Nelson's Electro-Metro Build thread bennelson Fossil Fuel Free 1499 12-22-2019 07:24 PM
DPoV's Jeepin' Build Thread DifferentPointofView EcoModding Central 26 12-16-2009 04:31 AM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 12:21 AM
JohnPR's oficial recumbent trike build thread johnpr Alternative Transportation 5 05-22-2008 12:50 AM
My Recumbent Thread - I found my 'bent trebuchet03 Alternative Transportation 4 12-31-2007 08:41 AM
