EcoModder.com
-   OpenGauge / MPGuino FE computer (https://ecomodder.com/forum/opengauge-mpguino-fe-computer.html)
-   -   Building my first MPGuino: Help? (https://ecomodder.com/forum/showthread.php/building-my-first-mpguino-help-21131.html)
revolt13 03-25-2012 02:15 PM
This thread was originally made to help me troubleshoot building my own mpguino but has now turned into my mpguino install thread. Hope you enjoy.
Ecky 03-26-2012 12:10 AM
You have all the parts right. The wiki has a link to some out of date software about 75% down, says something like "You must use version 0011 or it won't fit", but that isn't applicable for your Uno R3 because it has a bigger ROM (atmega328 vs 128). You could use it and it would work fine, but there's newer code available. This is a link to the latest code:
http://opengauge.googlecode.com/svn/...no/mpguino.cpp
To install it on your device, download the arduino software from here:
Arduino - Software
Once you have it open, copy and past the code into your empty sketch. You'll need to change a few lines because the prebuilt MPGuinos are 20mhz instead of 16mhz like the Uno, which will skew all of your numbers if not corrected for. If you scroll down just a bit in the code you'll see the following:
//use with 20mhz
#define cyclesperhour 4500
#define dispadj 800
#define dispadj2 1250
#define looptime 1250000ul/loopsPerSecond //1/2 second
#define myubbr (20000000/16/9600-1)
#define injhold (parms[injectorSettleTimeIdx]*5)/4
//use with 16mhz, not tested
//#define cyclesperhour 3600
//#define dispadj 1000
//#define dispadj2 1250
//#define looptime 1000000ul/loopsPerSecond //1/2 second
//#define myubbr (16000000/16/9600-1)
//#define injhold parms[injectorSettleTimeIdx]
"//" means the line of code isn't used, so add "//" to the 20mhz lines and remove them from the 16mhz lines so they look like the 20's did, or change the 20mhz section's values to be the same as the 16mhz section's. (that's what I did)
Make sure under "tools" you have the Uno selected as your board, and the right port (might take some trial and error if you have a bunch) and then hit Upload.
revolt13 03-26-2012 01:09 AM
Thank you very much Ecky, i was actually hoping you would be the one to reply because you seem to be the person who has most recently build and troubleshooted one of these. I will follow you directions to a T as soon as i get my parts. Will post pictures and maybe even make a tutorial for the forum if it would be helpful. Thanks again.
Ecky 03-26-2012 02:25 AM
No problem, I look forward to seeing your finished product!
revolt13 04-05-2012 05:23 PM
Got everything and soldered it all up, one row of the 16x2 screen has black boxes.. powers up good tho? That ok?
I tried uploading the code to it and it verifys fine but just keeps uploading?? Like forever.. :/ The RX and TX led's aren't flashing like the tutorial said it would either. HELP!!
Ecky 04-05-2012 06:54 PM
I know you probably have, but check your wiring again. Black boxes can be a result of one of the wires to the screen having a poor connection. I have a poor connection somewhere in mine and I get a line of black boxes if I drop it while it's plugged in.
What gauge wire did you use? If they're really small, I suppose it's possible that your poor connection lies not in your solder points but where you plug your wires into the arduino board.
As for uploading the code, you should be able to do it with a bare arduino board, you won't need the screen or wires to flash the ROM. I'll bring mine upstairs in a bit and see what it does when I flash it.
revolt13 04-05-2012 06:56 PM
Either it just keeps uploading or i get this error code..
avrdude: stk500_recv(): programmer is not responding
Yeah i took EVERYTHING off and just tried uploading the basic blink code and it wont. So discouraged. Idk what to do now? I chose the correct board and input..
Ecky 04-05-2012 07:37 PM
I seem to remember seeing that error code and I got past it somehow. In your device manager, make sure that when your Arduino is plugged in, you have a device called "Arduino UNO R3 (COM3)" under "Ports (COM & LPT)". If not you may need to install the drivers which are in the arduino folder.
In the Arduino program please check the following: under Tools->Board have "Arduino UNO" and Tools->Port "COM3" (unless yours is COM1) selected.
http://img213.imageshack.us/img213/6007/arduino1.png
Ecky 04-05-2012 07:43 PM
Under "Sketch" when I click "Verify/Compile", it says:
Binary sketch size: 17072 bytes (of a 32256 byte maximum)
^ Which is good. When uploading the sketch, try hitting File->Upload, rather than File->Upload using Programmer.
revolt13 04-09-2012 12:30 AM
So i got it all together and it works great! Only one problem, the first line of my 16x2 display is blank. So say the x's are what i want, this is what it looks like.. [ ]XXXXXXXXXXXXXXX The box is where its blank.. nothing shows up there nomatter what i do.
Im hoping its a defective lcd? HELP!
Ecky 04-09-2012 02:04 AM
Possible, but I'd be more inclined to check for a poor solder point or a wire not in the right place before ordering another.
revolt13 04-09-2012 02:23 AM
:( i checked almost everything. Its actually half of the first row.. so it cuts off just half of the first letter.
revolt13 04-09-2012 02:34 AM
Im about to say f this whole thing.. i've spent 10 hrs soldering this thing trying to get it to work and theres always something wrong.
Ecky 04-09-2012 08:05 AM
I know well how you feel. I'm not entirely certain what wire carries what signal but my common issues when assembling mine were quarter-screen blank/corrupted, half screen, or whole screen, which leads me to believe that each quarter probably has its own dedicated data wire.
If you're tired of fooling, it seems while you were working on yours JellyBeanDriver finished manufacturing a ton of really good looking premade MPGuinos. I'm tempted to retire mine for the smaller form factor his has and just use my arduino to reprogram the flash chip when updates come out to the code.
revolt13 04-10-2012 03:10 PM
Bought one from jellybeandriver, he does amazing work.
revolt13 04-14-2012 02:11 AM
Currently running the wires through my car, have them all installed but now my radio won't turn on :b. guess i have some wiring to work out lol. Will post pics and such when its all put together. I think im doing something with the install i haven't seen before :)
revolt13 04-16-2012 01:40 AM
Some new pics of how the install is going:
Injector signal:
http://s13.postimage.org/7figbaxev/photo.jpg
Where i ran the injector signal through the firewall:
http://s13.postimage.org/4myfirbtz/photo_1.jpg
VSS:
http://s13.postimage.org/47ikc00iv/photo_2.jpg
Power and ground from my stereo:
http://s13.postimage.org/82lyekjon/photo_3.jpg
How i "hid" my injector signal:
http://s13.postimage.org/m1e2dajl3/photo_9.jpg
Mess of wires:
http://s13.postimage.org/cn84ti3dz/photo_4.jpg
Phone jacks cut:
http://s13.postimage.org/imvvx5o6f/photo_5.jpg
Planning...
http://s13.postimage.org/f200dxjmv/photo_6.jpg
Planning...
http://s13.postimage.org/x3j5bqdnr/photo_7.jpg
Almost done:
http://s13.postimage.org/o78d7sn1j/photo_8.jpg
revolt13 04-16-2012 02:55 PM
Made some progress on the case today. Everything looks realllllly good :)
Phone jack in case:
http://s19.postimage.org/mcby7033n/photo_1.jpg
How i cut it to fit:
http://s19.postimage.org/tqwolmzlf/photo_2.jpg
Fan hole, there will be a screen added to keep dust out:
http://s19.postimage.org/6znlz8ek3/photo.jpg
And finally the screen hole, fits like a glove :)
http://s19.postimage.org/7doxytynn/photo_3.jpg
meelis11 04-17-2012 05:25 AM
Why do you need a fan?
revolt13 04-17-2012 11:52 AM
I don't NEED one, I wanted one. But unless I can find a switched ground it might not be worth the extra effort and I'll just use that as a vent hole. Believe it or not these black cases suck up some heat in the summer.
meelis11 04-17-2012 04:06 PM
If you want power to fan only when ignitiuon is on, then it is easier to use 12V from ignition (or use fuse box and locate fuse which is powered when ign. is on) and ground. I doubt you'll find switched ground.
revolt13 04-17-2012 05:01 PM
I'd rather not start cutting into my ignition harness, I already have enough wires going everywhere. Might just use a switched 12v fuse source.
JellyBeanDriver 04-17-2012 08:10 PM
I see now why you were asking for a +5V supply.
I don't recommend adding the fan. All you'd end up doing is adding more heat to the unit via regulator power dissipation. High heat on the LCD display itself may cause the image to darken, but it is reversible and true for all LCD's in the hot sun.
revolt13 04-18-2012 12:10 AM
Thanks for the advice, i will add a screen where the fan would have gone to allow some heat to dissipate.
revolt13 04-21-2012 04:04 PM
Long story.... but i had the mpguino working and in the box and i took it all out because the hot glue melted all over because it was sitting in the sun. I've since built it into my tach gauge and it looks great. Just need some new tact switches.
JellyBeanDriver 04-21-2012 04:42 PM
Bummer. Yeah, hot melt inside a car doesn't work well if the item is in the sun on the dash. Epoxy works well but isn't very reworkable.
revolt13 04-21-2012 05:31 PM
No worries, I'm much happier with the new install anyways. Pics will come when I get my switches in.
revolt13 04-27-2012 02:44 PM
Well i haven't got my switches in yet but heres a couple snapshots of the install. :) Comments are appreciated. I kind of copied another member who did it on his 94 civic coupe, but i think i did it a little cleaner. No light shines from around the display at night. Works great!
http://s19.postimage.org/4lsuta6cz/photo_4.jpg
http://s19.postimage.org/ncus3g0xf/photo_5.jpg
JellyBeanDriver 04-27-2012 09:23 PM
Wow! Looks great!
