Old 07-26-2008, 11:18 PM   #1 (permalink)
SaturnSl1 - '00 Saturn SL1
90 day: 40.21 mpg (US)
MyPickup - '96 Ford Ranger
CRX HF - '89 Honda CRX HF
90 day: 51.59 mpg (US)
Reducing Road Noise?
Anyone have some ideas on how to reduce road noise? My CRX is absolutely terrible on the highway.
I'm looking for a cheap way to cut down the noise. Any ideas welcome.
Old 07-26-2008, 11:49 PM   #2 (permalink)
adrive7's Avatar
Ranger - '08 Ford Ranger XL
90 day: 20.73 mpg (US)
Send a message via AIM to adrive7
dynamat everywhere.
Ohio State Baja SAE
Old 07-27-2008, 12:38 AM   #3 (permalink)
Red
Red's Avatar
Spray in bed liner on the wheel wells works
Old 07-27-2008, 12:53 AM   #4 (permalink)
Ecoformance Engineer
Vince-HX's Avatar
EJ7 - '96 honda civic Hx
Last 3: 58.02 mpg (US)
find a quieter tire, make sure all wheel bearings are in good condition
70 mpg or die modding
www.full-race.com
looking forward to seeing what kind of uber-sipper slinks out of the full race skunkworks.
Old 07-27-2008, 01:24 AM   #5 (permalink)
Box Dreamer
xB Commuter - '04 Scion xB
90 day: 40.76 mpg (US)
Agree with changing a new set of tires. Check with reviews on tirerack.com. Yokohama AVZ and General Altimaz are all quiet tires I tired. It makes huge different from the stock original.
Also, drive slower. Statistic shows the noise on 60mph is much quieter than 80mph. Both wind noise, engine noise and road noise are much less. I tried that and it is true. I believe this is the cheapest, most notable and fastest way to quiet down your car on freeway.
Old 07-27-2008, 02:43 AM   #6 (permalink)
What? THIS IS MY GOOD CAR
justpassntime's Avatar
The Japillac - '87 Honda Accord LXi Sedan
90 day: 31.77 mpg (US)
Ranchero GT - '73 Ford Ranchero GT
Spaz - '83 Chevy S10 4X4 Tahoe
90 day: 27.53 mpg (US)
Send a message via ICQ to justpassntime
You could use bedliner of some sort, sound deadening padding or dynamat. All of those require pulling the carpet out of the car with the exception of the bedliner. I used the cheap padding JC Whitney has under the carpet on my 73 Ranchero and used spray on bedliner in the bed. It worked really well.
Or you could do like people around here seem to do. Put a thumping stereo in your car and turn it up so loud it blows out all the bolts holding on the important stuff. Then one day when it coasts to a stop you'll wonder why it never gave you any warning.
Honda...the economical, renewable resource.
Old 07-27-2008, 10:57 AM   #7 (permalink)
Here's what I'm thinking. Tear off all the carpet, at least in the back under the hatch and put some of the carpet padding under everything.
For the wheel wells, I'm thinking I could spray some insulation foam in there. It wouldn't give me access to some of the wiring, but I figure if the electrical wires have lasted 20 years, they should be fine for another 10.
That seems like the cheapest way to do it. $25 for carpet padding and maybe $5 for insulation foam.
Old 07-27-2008, 02:40 PM   #8 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 62.77 mpg (US)
Install underbody panelling. A lot of "road noise" is actually noise created by the wind turbulence underneath the vehicle.
aerocivic.com
Old 07-27-2008, 03:01 PM   #9 (permalink)
bhazard's Avatar
2012 Golf TDI - '12 Volkswagen Golf TDI
90 day: 45.51 mpg (US)
I know I do want to do something about the noise in my festiva. Its rediculous in there going down the road. I also have some noise coming from the back end, like wheel bearings (which I JUST replaced) or flatspotted tires maybe.
'05 Outback XT, 19 mpg
BP-turbo 93 Festiva (long gone)
1/4 mile - 12.50@111.5
Best MPG - 36.8
Old 07-27-2008, 04:27 PM   #10 (permalink)
My underbody is surprisingly smooth. The only spot that air really gets stuck is when it hits the muffler, which sits about 2-3 inches lower than everything else. I'm thinking...other Honda CRXers can correct me, that this is because I don't have a stock muffler on my car.
I headed out to Menards a couple hours ago and bought $25 worth of 1/2" carpet padding (I wasn't about to pay the prices for padding meant specifically for cars). So far, I've finished installing it on the entire back half of the car. I also sprayed 2 cans of insulating foam ontop of each rear wheel well. Once I get the brakes fixed I'll be taking it for a drive.
Road Bike Update (and asking for more advice) Gone4 Alternative Transportation 7 09-03-2008 04:40 PM
Car making a scary noise jesse.rizzo Off-Topic Tech 5 04-12-2008 02:50 PM
Road Bicycle Buying Advice Gone4 Alternative Transportation 67 02-26-2008 08:40 PM
News: Maryland legislators may require cars to make some noise MetroMPG Fossil Fuel Free 9 02-22-2008 08:51 AM
If all the vehicles on the road were ultra-low Cd.... basjoos EcoModding Central 10 01-07-2008 08:34 PM
