EcoModder.com
-   Introductions (https://ecomodder.com/forum/introductions.html)
-   -   C-rex (https://ecomodder.com/forum/showthread.php/c-rex-31212.html)
C-REX 02-14-2015 03:43 AM
C-rex
4 Attachment(s)
New to ecomodders and just bought this little crx about 2 weeks ago. So far I have invested $562 in this little gas saver. and the best part is it drives, but it does have its problems the biggest one being the electrical issue that has possessed my dash cluster.
gone-ot 02-14-2015 11:34 AM
Nice little "pocket rocket"...welcome aboard!
C-REX 02-14-2015 01:04 PM
Thanks for the warm welcome
jimsiggy 02-16-2015 09:17 AM
Welcome
cRiPpLe_rOoStEr 02-17-2015 01:16 PM
I have already seen some folks working around those digital speedometers designed for bicycles (also often called "cyclecomputers") into older cars instead of fixing their stock speedometer. Who needs an all-stock cluster anyways? :D
So, what are you considering to do regarding the cluster? And is it fitted with a tachometer?
C-REX 02-17-2015 02:25 PM
yes it is fitted with a tech. After market. the speedo is the only thing that works right, tried replacing the cluster this weekend with one from the wrecking yard and the new one seemed worse. so now I am going to go all aftermarket.
