Calculating Drag Coefficient from top speed?
This look right to you guys?
Power (watts) = 1/2 (1.2(air density))(velocity cubed(m/s))(frontal area(m/sq))(drag coefficient). I know the car goes 80mph (35.2 m/s) and it has made 36hp at the wheels (1hp=745.7 watts) so ........ 36(745.7)=26845 26845=(.5)(1.2)(35.2(cubed))(1.9)(X=Cd) 26845=49720X 26845/49720=.53! So by this math, that means my Cd is .53!! Looks like my fuel economy is all light weight and small engine, and no aero. Thoughts? I have an G-Tech, so I might try a coastdown measurement later provided I can do the math LOL |
i don't have time to give you a full answer but you aren't considering your vehicle weight as far as i can see which will add some draw added horse power.
Friction Drag = Cf x cos theta x weight of vehicle where Cf is the friction coefficent of your tires, i would use somewhere around 0.012 if you don't have the exact number. theta is the angle away from horizontal, so 0 for level ground. also, be VERY careful with your units. I taught a Mechanical engineering lab where we calculated drag for vehicles and many students messed up the units. i am not sure where the 1.2 comes into your equation. hope that helps |
1.2kg/m cubed is the density of air at sea level at about 70 deg.
one other thought, is it making 36 HP at the wheels when it is going 80 mph or is that just its peak? just because it can make 36 HP doesn't mean its making it all the time. look on Instructables.com to find instructions on how to determine your Cd. i haven't done it but the instructions looked reasonably easy
Measure the drag coefficient of your car
I believe he provides a spreadsheet as well, so you don't have to do any math if you're not so inclined. |
I found this on the web, and we all know the internet wouldn't lie to us :D
Looks like I was a little off, probably because I didn't factor in any rolling resistance. "Among commercially available 1984 model street cars, the most aerodynamically efficient was the Audi 5000S, with a Cd of 0.33. The Chevrolet Corvette was close behind with a Cd of 0.34. Most other street models have approximate values of 0.40 (my wife's Chevrolet Chevette, I have discovered, is at the high end of the spectrum with 0.45)." Mine's an '82, but you get the gist of its aero properties. They're bad. Nosecone maybe?? |
formula
Hello -
Sounds like a job for the Bonneville Salt Flats : The Open Road: Racing the Bonneville Salt Flats Quote:
2007 Speed Week Results CarloSW2 |
anyone
...if you know the engine's HP-rating at the engine speed you're driving, you can backsolve for the value Cd·A in the below equation that's commonly used to estimate drag-power (HP) versus vehicle velocity (V):
V = 53.26 × [ HP/(Cd·A) ]^(1/3) HP = (V^3)×(Cd·A)/151130 (Cd·A) = (151130×HP)/(V^3) ...because this equation assumes HP(aero) = HP(engine) and doesn't include HP(tires), you probably need to assume only 90% of HP(engine) is usable. |
some numbers
Cd 0.51 Frontal area 18.6 square-feet Curb Weight 2,050 pounds -------------------------------------------------------------------------- Car and Driver did a road test comparison between a gasoline Chevette and Diesel Rabbit.Here are numbers for Chevy: 30-mph= 40 mpg 40-mph= 37.5 mpg 50-mph= 33 mpg 60-mph= 28 mpg 70-mph= 22 mpg 80-mph= 17.5 mpg -------------------------------------------------------------------------- None of the road tests included top speed.Chevy's competitor,the 1982 Ford Escort was tested flat out at 87 mph. -------------------------------------------------------------------------- The OPEL Junior concept car of the 1980s would be a good car to mimic with the Chevette.It achieved Cd 0.30 with a remarkably short overall car length. |
