Calculation for fan draw?
I did a simple measure of how much voltage drop the battery experiences with my cars fan:
No fan - 14.45V First setting - 14.40V Second setting - 14.35V Third setting - 14.31V Fourth setting - 14.27V I have this data but don't know how to apply it for determining power drain. The car is an '09 Focus. I tried googling to find alternator specs but was unsuccessful. On older Focus's the alternator was 105amps. I would suspect mine is probably close to this but even if I use this value, isn't this only true at high rpms? Would the equation Watts = Volts x Amps be applicable or is there a change of amps with rpm? I also wonder if I can further use this to calculate horsepower drain by Hp = (Volts x Amps x Efficiency) / 746 But I don't know what to use for efficiency and I once again wonder if efficiency changes with rpms? Anyway, if some of you could help me make some useful information from the voltage measurements ... I'd appreciate it! Doug |
...you gotta know the AMPS and VOLTAGE being used by the fan, not what the alternator is rated at.
...take both a VOLTAGE and AMPS reading...that'll give you the wattage at that setting, then divide by 746Watts/HP and you'll have a HP value at 100% assumed efficiency. |
Okay, I was hoping that somesort of assumption could be made but getting a direct measure makes sense. I also appreciate the comment that 100% efficiency can be interpreted for the simple equation.
Thanks! Doug |
...DC motors are fairly efficient (~85-95%) but their fan blades are NOT! So, total electrical power (HP.e) will be greater than the true mechanical power (HP.m) needed to move a given volume of air...that is, you're gonna put "in" more HP than you effectively get "out," ie:
efficiency = Power OUT / Power IN = (HP.m / HP.e) |
Well, even if the 100% efficiency is off, the calculated power ratios from no fan to maximum fan should be correct even if the calculated power usuage from efficiency is a bit off. My concern would be more if there was a signficant variability with rpms, say ... 45% at 1500rpm to 95% at 6500 rpm.
Do you think it would be safe to assume fairly equivalent efficiency value across the full rpm range? Doug Edit: negate that, I re-read your post and find I'm confusing the ICE with the fans motor. This is correct isn't it - the efficiency parameter is in consideration of the electrical motor. |
...a fictious example: it'll take 100HP of electrical power to "blow" 80HP of mechanical air movement.
...the biggest "loss" is due to the fan-to-air coupling, not the motor-to-fan coupling. |
Thanks OTM!
Fan efficiency is a very complex topic.
Quick Shot review 11: Thermaltake Extreme Volcano 12 Quote:
The power draw is less than the rating of the blower motor fuse / relay.
http://ecomodder.com/forum/showthrea...olts-8908.html MetroMPG's Metro is much thriftier than most cars, so your fan probably draws more power than his. http://ecomodder.com/forum/showthrea...aseo-8767.html |
