Old 12-30-2008, 08:54 PM   #1 (permalink)
Trouble Code PO401 EGR Flow Insufficient Detected
My daughter in law brought her car to me about the check engine light being on the other day so I hooked up the code reader and got PO401 EGR Insufficient Flow Detected. I took the EGR valve off and cleaned it and the EGR port on the intake manifold and put it back together and it solved the problem. I just wanted to post this in case anyone else ever gets this code, but be sure to clean the port in the intake. Her car has a port about the size of the end of my smallest finger and was nearly completely stopped up. The auto parts store had told her she needed a new EGR valve. WRONG!!!
Old 12-30-2008, 10:10 PM   #2 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
That is why I use Seafoam regularly. Carbon deposits are bad.
GeoMetroforum.com - got mpg?
Old 12-31-2008, 10:09 AM   #3 (permalink)
metroschultz's Avatar
CPT SLO - '93 GEO Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Toyota Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
I don't think SeaFoam will help these Johnny,
The port goes through the intake for about 7 inches and is quite small as he stated.
It gets plugged with carbon from the cooling exhaust gas passing through it.
in earlier models ford ran coolant passages beside it to keep it hot so the gasses wouldn't coke up, in later models they widened the passage. And all Fords have this problem. I've cleaned hundreds. From Crown Vics and Lincolns to Escorts to F series trucks.
When you are courting a nice girl an hour seems like a second. When you sit on a red-hot cinder a second seems like an hour. That's relativity.
Albert Einstein
Old 12-31-2008, 10:16 PM   #4 (permalink)
Hi-Tech Redneck
I was a Ford tech for a few years. The police Crown Vics (CVPI) got regular water or seafoam treatments.
Old 12-09-2011, 12:45 PM   #5 (permalink)
thanks for your info almost spent to much money!
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 02:47 PM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
