Call out for test data and mod instructions for wiki
Hi All,
A few of us are getting very useful info into the wiki but we are lacking a lot of “how to” instructions and efficiency test results from many mods (I haven't done all the mods yet). I have had a search through many of the threads and put data into the wiki based on some of that info however a lot of good info is hard to find in the many threads and its very time consuming trying to find the info. So to all the Ecomodders out there, if you have any test data (ABA test or tank fill up result that isolates a single modification) then please either PM me or post on this thread and ill be happy to put any relevant data into the wiki. If you have already posted your info in one of the threads or if you have seen some really good info in a thread that isn’t on the wiki post a link to the thread and ill get it into the wiki. Of course your all welcome to modify the wiki's yourselves :). For a list of mods we need more information on have a look at the wiki, which is located here, the table summarizes what info we still need. Car Modifications Main - EcoModder or here is a list of mods we need efficiency info on. Lean burn indicator Vacuum gauge Mud flaps (deletion) Raised wing type rear spoilers (deletion) Shave badges, door handles, rain gutters, etc. Windshield wiper (deletion) Aerodynamic front bumper cover Swap/fabricate Boat-tailing behind tires Decrease hood to windshield angle Front wheel arch gap fillers Frontal area reduction Pickup truck aeroshell/fastback bed cover Pickup truck tonneau cover (partial or full) Rear corner airflow trip feature Ride height reduction Sealed panel gaps Soften / radius aft edge of front wheel arches Tire spats, or fully contoured deflectors Upgrade headlights from "bucket" or pop-up style to aero assemblies Wheel skirts front Advanced ignition timing Economy camshaft swap Engine kill switch for easier Pulse & Glide / Engine off Coasting Engine swap Hot / warm air intake Increased compression ratio Use lowest viscosity engine oil recommended by OEM A/C delete Block Heater Electric coolant / water pump Mechanical to electric radiator fan swap Power steering delete / manual steering rack swap Regear for lower cruising RPM Swap from automatic to manual transmission Synthetic axle/wheel bearing lube Use thinnest transmission / differential oil recommended by OEM Solar 12v assist Lightweight wheels Replace tires with low rolling resistance tires Replace tires with skinniest tires recommended by OEM Aftermarket cruise control Cruise control mod: fuel economy logic Hybrid conversion Weight reduction Aero fairings Sprocket swap Automatic transmission manual gear control (Manumatic) Torque converter lock up control Windshield wiper cover |
