Cam AND Ignition timing?
Hey I'm changing the timing belt today and was wondering, would it benefit me to advance the stock cam gear? I do 90% interstate driving so how many teeth advanced should I go? And also how many degrees should I go on the ignition timing with it? Everything is set stock right now (btw its a 97 1.0L) Thanks:turtle:
nevermind... I know now why I couldn't find it... one tooth is way too much... i'll just wait for an adjustable cam gear... unless anyone knows of a way to adjust a little bit with the stock gear
bad idea
in a G10 advancing the cam at all is a very bad idea
it seems like it should be a good idea but it is not the exhaust lobes get advanced along with the intake lobes and the end result is that the exhaust valves close before the combustion gases can be expelled , before TDC .... i had installed a +10 cam wheel from 3tech , every thing got worse so i checked to see why http://farm5.staticflickr.com/4131/4...2b7b57fb_b.jpg look inside the red oval that peak upward shows pressure where there should be no pressure overlayed on the pressure waveform of the same engine without advanced cam timing http://farm4.staticflickr.com/3478/3...88b47182_b.jpg this is how you measure it ... that fluke pv350 pressure transducer is connected to a digital storage oscilloscope either Pico 6 or ATS Escope . learn from my pain do NOT advance cam timing on any G10 |
