can someone run this through a flow simulator for me?
1 Attachment(s)
IsaacCarlson -
Here you go : http://www.youtube.com/watch?v=T85s1KUlxb8 I downsized the image to 256 pixels wide and expanded the "canvas" of the image for a 256x128 pixel proportion. CarloSW2 |
Thank you! Looks like I have some fabbing to do.....now where did I put the cardboard and duck tape?
And then I measured it and found both to be around 20° |
euromodder -
The original image is larger than what Flow-Illustrator likes to consume. It can consume up to 512x256, but I use 256x128 because it's more reliable. That results in an rougher/grainer silhouette. CarloSW2 |
The rear would be lower in real life. I accidentally ran the bmp up to the bumper, not the hitch. The hitch hangs down lower and would make a good attachment point for mods.:D
Yeah, the steepness is causing turbulance that is messing with the upper flow.
maybe a small horizontal lip on the bottom to redirect it back ? |
