Capacitor Bank for Open Revolt: What Size?
So I'm working on our controller using the new and improved controller PCB, the SMD current sensor, and the VLA based IGBT driver from mrbigh.
Here's what we got for IGBTs: 4x Fuji 300A 1200V Running these IGBT's together would give 1200A. We plan on setting it to 1000A max current. Based on what Paul said long ago in the main thread: Quote:
Is capacitance tertiary to getting a low ESR and high ripple current rating, or does it matter just as much? Looking for best as well as least expensive route. Thank you all! :thumbup: |
Picking capacitors is really, really hard. It's all about trade-offs.
The primary task is to clamp the voltage spike from drive turn-off. If you can't absorb the energy, the voltage spike will avalanche the MOSFETs or IGBTs. So you need at least a minimum capacitance to handle the inductive surge. We can't tell you how much that will be, since it's highly dependent on the batteries, the battery condition, and the details of the battery cable runs. If you have the bare minimum, the capacitors will have to deal with a high ripple voltage/current. They'll need a low ESR to not overheat from the current, and a high ESR to limit the current. You can't have both, so you'll need more capacitors to both lower the per-cap current and spread the heat out. If you are designing for this regime, you pretty much need to use polyester (Mylar) film capacitors. If you increase the capacitance beyond the minimum, with capacitors that can handle the current, the ripple voltage will decrease. That will decrease the dV/dt, which will widen the range of capacitors you can use. At this point you can start using aluminum electrolytic capacitors. Continuing to that corner of the design space, you can minimize the ripple voltage rather than just barely handle it. The means much more capacitance, generally a dozen or more high density, moderate ESR capacitors. Generally these are connected close to the battery cable input to the bus bar, with low ESR film caps connected close to each switching device itself to handle the inductive spike from the bus bar. A side note about this: mixing capacitors with different characteristics can be effective at reducing noise and the peak voltage. Or it can create its own ringing as current "sloshes" back and forth between capacitors. Sometimes you just have to built it and measure. In general, when picking capacitors you should avoid physically large surplus ones. They are usually designed for power supply filtering, especially handling brief power flickers. They can handle a small ripple voltage at 60Hz, and a partial discharge every once in a while. If you have them absorb the same ripple voltage at 15KHz, that's 250x the power they were designed for. They will heat internally and they don't have the surface area to volume ratio to get rid of the heat. |
Now, why would do something like go and confuse me like that? :) Lots of info in there, some of it is helpful, some of it makes me realize I've forgotten a LOT of stuff and need to research to fill in some holes. That's why I'm doing this with friends; one is a mechanical/electrical engineer.
If we're going with twice the amperage, do we need one, all other things being equal, that's twice as many caps (of the same type) as the 500A controller? Can we go with the same number of caps if we have twice the ripple current handling ability? :) |
My original igbt design use 2 x 1500uf 450v and 2 x 4700uf 450v caps. They don't even warm up. Driving for over a year. My motorcycle controller uses 2 x 6800uf 250v and my new liquid cooled design 3 x 4700uf 400v. My theory being that its a pain to deal with lots of little pcb mount caps and its really a game of swings and roundabouts. I also used 1uf 400v film caps. one across each of the big boys.
Sounds good, Jack - but I'm also wondering about expense. I'll have to see what I can rustle up from the guy at the welding repair shop - I might be able to get free caps! :) (there will be a different thread explaining that later today).
Ring Capacitors
For those interested in DC Link Capacitors used in IGBT based inverters.
This is a link to the Capacitor Manufacture that EVnetics is using in the 1000 Amp Soliton: SBE inc. (SB Electronics) Developer and Manufacturer of Film Capacitors -Mark :D |
Those are incredible. how did you find that out?! I don't think they were very excited about that information getting out.
Future carries them:
SBE INC | 700D10896-348 | 700D Series 600V 1000 uF ±10% Metallized Polypropylene Power Ring Film Capacitor - Future Electronics Well, they are out of stock, but HOLY COW THAT'S A CAPACITOR!!!!!!!!! |
I knew they were using those Ring Capacitors for more than a year now. The only reason I shared this info was it became public on May 12th, on the SBE's website. -Mark |
The quote from Paul was interpreted wrong. "You only need like around 5% of the max current for ripple rating, so they say. 50% is the worst case scenario." Its 5% of the max current of the worst ripple. The worst ripple is at 50% duty so 500A then take 5% of that. I like to work higher then that in the 25% area, 125A. Like DJ said, your best bet is to use a bunch of low ESR caps in parallel and throw in some polyester or polypropylene caps for high current rating. But be careful for ringing. What voltage do you plan on running with these IGBT's? -Adam |
Not more than 144VDC. Well withing derated margin, yes? 4x300=1200A, set controller to 1000max limit, not that we'll ever see 1k amps without serious money into batteries.
I like JackBauer's approach of "Few big, few small." However, I'm not sure if it will cost more or less to go that route as opposed to "hordes of small." |
1 Attachment(s)
I have been digging for several hours now.... looking for a schematic of where these big caps go....
I love adams and (something alaska) have been doing with the ring cap and the IGBT's it looks soooo sweet... question is: do the caps go on the supply side of the motor controller?? this is the only reason a B+ goes to the motor controller ?? since the controller turns on and off the M- ?? does the third lug of the IGBT go to anything ?? how does the IGBT get wired up ?? B = battery - C = motor - ?? A ???? |
The cap goes on the supply side as close as possible. The terminals on the IGBT are A = Motor Negative (M-) B = Battery Negative (B-) C = Battery Positive / Motor Positive (B+/M+) The most important factor of a motor controller capacitors is not the capacitance, but the ripple current ability. You must be able to control and withstand the current pulses or else you will destroy things. -Adam |
