EcoModder.com
-   Aerodynamics (https://ecomodder.com/forum/aerodynamics.html)
-   -   Car Aerodynamic Testing - 2nd edition (https://ecomodder.com/forum/showthread.php/car-aerodynamic-testing-2nd-edition-39219.html)
JulianEdgar 03-21-2021 11:58 PM
https://i.postimg.cc/8kK0d849/cover.png
For anyone interested, I have published a second edition of my Car Aerodynamic Testing book.
Contents:
Chapter 1 – The approach
  • The different tests
  • Testing techniques
Chapter 2 - Airflow testing with tufts
  • What you need
  • Airflow patterns with tufts
  • Tuft testing a Tesla Model 3
  • Tuft testing vortex generators
  • Tuft testing a rear roof extension
  • Tuft testing a wiper deflector
Chapter 3 – Airflow testing with dust
Chapter 4 – Measuring panel pressures
  • Pressure sensing puck
  • Reference pressure
  • Gauge
  • Measuring pressures
  • Professional pressure measurement
  • Over-car and under-car pressure readings
  • Pressure readings in rear spoiler development
  • Pressure readings in rear separation edge development
  • Pressure readings across a standard under-hood intercooler
  • Pressure readings when optimising downforce
  • Pressure readings with a rear spoiler and fins
  • Pressure readings to show flow attachment on the sides
  • Centreline pressures on different car shapes
Chapter 5 – Using pitot tubes
  • Using a pitot tube to optimise a rear diffuser
  • Using a pitot tube to measure air speeds
Chapter 6 – Measuring lift and downforce
  • Ride height sensors
  • Measuring the effectiveness of a rear spoiler and wing
  • Measuring downforce of a hatch-mounted wing
Chapter 7 – Measuring changes in drag
  • Windows open/windows closed
  • Ride height
  • Rear wing angle
Chapter 8 – Reducing lift and drag
  • Reducing lift
  • Reducing drag
  • Reducing both
Chapter 9 – Fallacies!
  • Don’t use a template
  • Lift is important
  • Lift is not usually caused by flow separation
  • Ignore the 10% / 5% rule
  • And finally….
Appendix
  • Air density
  • Equations for pressure, speed and density
  • Calculating coefficients of pressure
It's available at the web address below.
