EcoModder.com
-   Instrumentation (https://ecomodder.com/forum/instrumentation.html)
-   -   Car enters close loop instantly, instrument fail? (https://ecomodder.com/forum/showthread.php/car-enters-close-loop-instantly-instrument-fail-25731.html)
jayliu1984 05-03-2013 01:21 PM
Hi, I just got a scangauge like tool yesterday and I have noticed that this morning, my car enters the close loop almost instantly after I started it.
The car is 2009 accord and is parked in a garage, the ambient temp this morning is somewhere 14 C.
Is this possible? is there something wrong with the instrument I got?
I am thinking I should test it by stepping hard on the gas and see if it changes to open loop, will this work?
Occasionally6 05-03-2013 09:52 PM
If your Accord uses a wide band O2 sensor it's possible that it always operates in closed loop. I don't know if that is the case though.
Do you have another car or neighbour or friend with a car that uses OBDII that you can check the gauge against?
AndrzejM 05-05-2013 04:32 PM
You should check coolant temp if it's close to ambient after a night in a garage. Maybe temp sensor is telling ECU that engine is hot. Or maybe you have wideband O2 sensor like Occasionally6 says.
jayliu1984 05-06-2013 01:48 PM
The strange thing is... it stay in close loop whenever I cruise, coast or idel, but as soon as I put ANY LOAD on the engine, it jumps to "open loop - driving".
It is a chinese developed tool (which is of very good quality and feature), but I am not sure why that status exist..
It has 3 status, open loop, close loop and open loop - driving (litterally translated from on screen chinese).
AndrzejM 05-07-2013 03:08 AM
Strange indeed, but I think that's the "SGII like tool" issue not the car itself.
Rusty94cx 05-07-2013 03:19 AM
I think you do have a 5 wire 02. Newer accords do.
redpoint5 05-10-2013 10:02 PM
My '06 TSX goes closed loop instantly no matter how cold it is outside. The only time it goes open loop is when I DFCO. Handy indication to show what RPM I must exceed to attain DFCO.
