Car to run compressed air.....
Got this in an email today. The pictures would not copy over. Interesting though.
Will it be the next big thing? This is the company that currently owns Jaguar Company in England. Will it be the next big thing? Tata Motors of India thinks so. What will the Oil Companies do to stop it? It is an auto engine that runs on air. That's right; air not gas or diesel or electric but just the air around us. Take a look. Tata Motors of India has scheduled the Air Car to hit Indian streets by August 2012 The Air Car, developed by ex-Formula One engineer Guy N. For Luxembourg-based MDI, uses compressed air to push its engine's pistons and make the car go. The Air Car, called the "Mini CAT" could cost around 365,757 rupees in India or $8,177 US. The Mini CAT which is a simple, light urban car, with a tubular chassis, a body of fiberglass that is glued not welded and powered by compressed air. A Microprocessor is used to control all electrical functions of the car. One tiny radio transmitter sends instructions to the lights, turn signals and every other electrical device on the car. Which are not many. The temperature of the clean air expelled by the exhaust pipe is between 0-15 degrees below zero, which makes it suitable for use by the internal air conditioning system with no need for gases or loss of power. There are no keys, just an access card which can be read by the car from your pocket. According to the designers, it costs less than 50 rupees ($1) per 100 KM (62 miles), that's about a tenth the cost of a car running on gas. It's mileage is about double that of the most advanced electric car, a factor which makes it a perfect choice for city motorists. The car has a top speed of 105 KM per hour or 60 mph and would have a range of around 300 km or 185 miles between refuels. Refilling the car will take place at adapted gas stations with special air compressors. A fill up will only take two to three minutes and costs approximately 100 rupees (about $2) and the car will be ready to go another 300 kilometers. This car can also be filled at home with it's on board compressor. It will take 3-4 hours to refill the tank, but it can be done while you sleep. Because there is no combustion engine, changing the 1 liter of vegetable oil is only necessary every 50,000 KM or 30,000 miles. Due to its simplicity, there is very little maintenance to be done on this car. This Air Car almost sounds too good to be true. We'll see in August. 2012 |
Been there, done that.
Been waiting a while for this "revolutionary" vehicle. Air power is not rocket science or new.
5 year old design.
Original range claims never confirmed in 5 years. Pay special attention to the fact it takes 30 KW of electrical energy to store 14.3 KW of air power. Compressed air car - Wikipedia, the free encyclopedia It may work for very short haul in India, but it will never work in the US. Efficiency overall listed at 5-7%. regards Mech |
I would think that it comes down to compressor efficiency. Fill ups done at central locations using ginormous highly efficient compressors is probably economically feasible. Doing at home on a small electric compressor, not so much.
And how large is the tank? What pressure is it at when full? Is this a safety issue? Would it turn your car into a rocket, were it to come uncorked? |
You guys should dig for the threads on this that are already here.
Sorry, but I had to. |
