A car in the supermarket carpark
In another thread I asked about modding the hatch on a Geo Metro, and this is exactly on point, so thank you.
2. The longitudinal strakes, I suggest, perform the function I ascribed to them in the video. I don't see the longitudinal filler strips doing much to cause separation. 3. Step not slot. And such a small step it would be of no consequence I would think. |
1. Can you propose a word to describe a small scale disruptor to modulate the flow around a larger feature? 'Gurney flap' wasn't named for an airplane pilot.
2. I though it was a weak point due to the average 7° crosswind. 3. Okay. I suspect it's a manufacturing issue, avoiding trying to fit to the hatch edge. |
2. Where did you get that figure from? That's much higher than any data I have seen. 3. Yes I think so - need a minimum thickness in the moulding. |
A DuckDuckGo inurl: search find one hit, no numbers. I'd care more, but it's sunny outside. |
I found it. It was in a reference hearsay by you-know-who.
ecomodder.com/forum/showthread.php/hidden-real-drag-coefficient-39010.html#post640594 |
You're right, of course. It was in imperfect recollection. Hopefully the cite will appear.
rear wing feature
The only thing I can make of it is, that those leading structures are hiding a particular type of hinge which allows the hatch to clear the roof when it's raised, rather than be immediately broken off, or jam.
I could see an external hinge, but they went out of style in the 1950s.
https://s1.cdn.autoevolution.com/ima...age-4571_7.jpg |
wrong again
I don't have the car to examine. I've had to confront clearance issues like this with my own projects. Civility is nice too! |
enlarge
I never saw anything in the video which helped explain the hinge. If the light-green car has the same rear spoiler as the original image, I don't see how the hatch could possibly open without interference. |
A recessed hinge has the edge move outward and forward. This is really a minor detail compared to it's function.
I found a Jetta deck-lid spoiler that is the right width and curvature to match up to the Metro. All it needs is sail panels. I'll take a pic. |
So yes, maybe the forward bumps are for the hinges (even though it doesn't look like that from the inside view). So in this case I was too quick to dismiss your point, and I apologise for that. |
3 Attachment(s)
You might find these photos useful .
Gurney flap only applies to Wings ok ,what is the proper technical term to describe a gurney flap shaped protrusion on a Leading Edge attached wing AKA spoiler?
Why does the rule book for Bonneville ,El Mirage, ect LSR say that Granny flaps are allowed on a Bonneville spoiler, the same rule specifies that the Leading Edge of the wing be attached therefore it is a spoiler with an allowed Gurny Flap? I don't know of a more technical writing than a rulebook for racing. Southern California timing Association 2019 rules and Records , Rule # 4.CC.8 pg60 , 1 , "Gurney flaps are allowed but cannot extend above or behind the spill plates" (2"aft or 8"above) |
Anything above or below a wing is called a fence generically. Flaps are hinged things that deploy to alter airflow.
See also: Starship.
blind in one eye, couldn't see out of other
Parked next to a Mirage last Sunday. Obviously, the actual rear hatch gap was clearly in the original photograph. My brain, somehow couldn't accept the fact that this gap could be so far ahead of the trailing edge, and dismissed it.
Apologize for confusion and Armadillo-vision. :o |
Gurney flaps sole purpose is to give a simple basic flatish/concave shape a more complex convex curved air flow/ boundry layer pattern without the complexity Quote:
Wickerbill = trim tab on full lock.
Dan Gurney also invented the Gurney Bubble. https://www.thetruthaboutcars.com/wp...ey-550x309.jpg www.thetruthaboutcars.com/2014/11/gurney-bubble-gurneys-bubbly/ Quote:
It's interesting, in light of recent controversy, That this comment highlights that the squareback 'bread-van' body killed Ken Miles. The solution was a fastback. :confused: Quote:
