EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   Carbon footprint sectors (https://ecomodder.com/forum/showthread.php/carbon-footprint-sectors-41264.html)
sgtlethargic 01-13-2024 05:28 AM
Has anyone seen good information on which sectors of our lives have the biggest carbon footprint? Transportation, diet/food, household, job, and hobbies seem to be the major sectors. Transportation should be obvious. Diet/food: consumption of animal products. Household: HVAC is probably the biggest factor. Job: I used to drive for a job. Hobbies: If one flies an airplane for fun.
oil pan 4 01-13-2024 10:44 AM
1 Attachment(s)
https://ecomodder.com/forum/attachme...1&d=1705159577
Transportation is nearly a third. Of that personal vehicles are only around 10%.
So buying an electric car is wholy ineffective as most of the emissions are being cranked out buy heavy trucks, planes and trains.
Agriculture is 11% so eat whatever you want it won't make a difference, if you eat a "climate friendly diet" you're getting more of your fresh green food shipped by air from south America or pacific islands. So most of whatever you think you'll save there is just going towards burning jet fuel.
Biggest energy user in homes is an electric vehicle if you have one and HVAC. For me I burn fire wood so I use hardly any electricity during the winter. If I didn't have my leaf my power bills would be about $30, 2/3 of that being the service charge.
For summer I have split air conditioners so I only cool 0 to 2 rooms of my house, weturn it off during the day while where away. The splits can cool down a hot living room in about 10 minutes. About 28 out of 30 days a month my central A/C stays off.
The splits and wood stove save hundreds of dollars per month in electricity during the summer an winter.
freebeard 01-13-2024 12:38 PM
Breathing emits CO2.
sgtlethargic 01-13-2024 12:52 PM
Your pie graph must be for the entire US. I'm asking for and talking about on the personal level.
That's not true, according to the quote from the following link, which seems credible:
Quote: Transporting food by plane can come with a large carbon footprint. But very little of our food travels this way – just 0.16% of food miles are from air travel.
https://ourworldindata.org/food-transport-by-mode
I don't have an EV. I wouldn't mind having a Nissan Leaf.
I used to live in the foothills and burn firewood in a wood stove. I would use "mini splits" and not burn firewood. Some people say that burning firewood is carbon-neutral, and it might be, but burning firewood releases that sequestered carbon, and NOT burning it keeps it sequestered. And (some ways of) burning firewood creates a lot of particulate pollution.
I would like to have mini splits, but I was able to fix my old HVAC system for cheap, and the buy-in is more than we can afford.
How do the mini splits do for heating? I would think they'd do just as well or better than they do for cooling.
sgtlethargic 01-13-2024 01:02 PM
1 Attachment(s)
Also, one can do what they can to reduce the harms they cause and contribute to. I try to reduce my contribution to US militarism because it's horrible in several very important ways. I personally cannot stop nor slow US militarism, but I can take an ethical position and do what I can to not support it.
US militarism ("defense") is said to be the #1 institutional burner of petroleum:
sgtlethargic 01-13-2024 01:10 PM
https://www.nrdc.org/stories/do-we-exhale-carbon
oil pan 4 01-13-2024 02:48 PM
Mini splits kind of suck for heating that's why I might leave them on the lowest hest setting and use the wood stove.
Tonight it's going to be about 0f outside. Inside my house is going to be about 78f. If I used heat pumps it would be more like 59f and would take a ton of electricity.
Plus this is America you can have s centeral HVAC and splits. I have a centeral heat pump HVAC, splits, wood stove, coal furnace and propane heaters.
I highly recommend not consuming fake foods like soy or oat milk. If it's plant based what it really means is a chemical plant.
oil pan 4 01-13-2024 02:51 PM
I looked it up once the military uses something to the tune of 300,000 barrel of oil per day.
More nuclear powered ships in the navy could reduce that. The army and air force aren't allowed to have nuclear energy reactors.
redpoint5 01-13-2024 06:20 PM
Most people don't realize that what they breath out is heavier than what they breath in. Loosing weight is a respiratory process, and that weight is going to be lost through the exchange of lighter weight air for heavier. The body literally burns calories and exhausts the combustion waste.
Hard to lose weight breathing harder, but easier to put less fuel in the tank in the first place.
oil pan 4 01-17-2024 09:15 AM
1 Attachment(s)
Originally Posted by jannickz (Post 691270)
As you mentioned, this is often the biggest contributor globally, accounting for around 28% of global greenhouse gas emissions. Factors include driving cars, flying, and public transportation (particularly if powered by fossil fuels).
The biggest thing that can be done is get more nukes producing electricity.
"Renewables" are struggling hard to make more than 30%. Now it's getting to where every state needs to reengineer their power grid, upgrade capacity and add thousands of miles of new power lines. We sure are cutting down a lot of trees, mining a lot of copper/steel and making a lot of concrete in the name of saving the environment.
https://ecomodder.com/forum/attachme...1&d=1705501082
Hersbird 01-18-2024 08:58 AM
These pie charts are only man made sources. If you included natural sources the natural section would be over 90% of the pie by itself.
