Old 11-18-2016, 06:33 AM   #1 (permalink)
VW GOLF - '96 Volkwagen Golf MK3 GL
90 day: 50.21 mpg (US)
Commute scoot - '95 Suzuki AE50 Style
Last 3: 70.4 mpg (US)
The German - '99 Mercedes W202 C200 Classic
90 day: 27.65 mpg (US)
Mercedes W202 C-Class - Aero Build Thread
So, I've got a new (old - very old) car
Hucho
and some aluminium composite board...
The old beast gets 20mpg(US) around town and 31mpg(us) on the motorway cruising at 70ish - I got used to high 40's MPG(US) with my old car so time to get modding.
I though a build thread may be better than individual parts builds as I did with my old car. I'm a grown-up now so progres is likely to be slower...
The board will be saved for an undertray project which I am not sure about beause (1) my car is RWD so has a driveshaft and diff to keep cool / clear; and (2) the exhaust is massive and hangs way lower than the rear bumper.
I have form building trays, so hopefully I can get it done and dialled in:
http://ecomodder.com/forum/showthrea...1-a-12816.html
There's a good pic of the wake of the same model C-Class as mine in Hucho at pp.314
Tomorrow (when I'm not at work) I plan to complete some / all of the following:
(1) grille block (manually adjustable).
(2) air dam (as a sticking plaster before the tray build).
(3) R-wheel skirts - perhaps, Hucho says they are worth a measley less than 0.01 cD.
What I will probably end up doing iinstead is:
(1) building an MPGuino and identifying the car's connections.
(2) ripping my (OEM cassette) radio out and soldering an AUX input to the soudn processor chip.
(3) putting lots of snowboarding stickers on the car.
(4) trying to find some 15" pizza pans cheap - though the stock wheelcovers seem pretty flat.
Wish me luck....
Will you recoup money spent on mods in fuel saved? see my spreadsheets here
Old 11-18-2016, 07:20 AM   #2 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 40.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 30.12 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 37.82 mpg (US)
Ralica - '85 Toyota Celica ST
90 day: 25.23 mpg (US)
Sx4 - '07 Suzuki Sx4
90 day: 32.21 mpg (US)
F-117 (2) - '03 Citroen Xsara VTS
90 day: 30.06 mpg (US)
I wouldn't bother with pizza pans, if you really must just use excess composite board to fill in the openings.
Old 11-18-2016, 07:40 AM   #3 (permalink)
good advice I think - looking at the wheel covers, I'm not sure of the relative advantages of moon discs
Old 11-20-2016, 12:36 PM   #4 (permalink)
So.... Not much aeromodding has gone on, but I HAD to do something about having no aux in on the stereo....
That gave me the chance to run MPGuino wires for the VSS (fed to the stereo) and through the bulkhead for the injector feed.
The MPGuino build is coming on slowly as the wiring for the LCD is "old school" (16pins rather than 4) - is up and running on a breadboard:
Also couldn't resist sticker bombing the horrible (but real) wood on the dashboard...
Must be worth 10mpg at least!
The Following User Says Thank You to sallen For This Useful Post:
Ecky (11-20-2016)
Old 11-20-2016, 04:44 PM   #5 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
For improved mileage you are supposed to put the repulsive shït on the back of the car.
The Following 2 Users Say Thank You to jakobnev For This Useful Post:
LittleBlackDuck (11-20-2016), oldtamiyaphile (11-20-2016)
Old 11-20-2016, 07:03 PM   #6 (permalink)
LittleBlackDuck's Avatar
CT - '11 Lexus CT200h Luxury
More like -10mpg due to the stops required to puke
Simon
Old 11-21-2016, 03:00 PM   #7 (permalink)
Tinkerer
kafer65's Avatar
Silver - '15 Mazda CX-5 Sport
Team Mazda
90 day: 37.23 mpg (US)
My eyes hurt.
Could have sanded, stained and rattle can cleared the wood but I know that's a lot of work. I drove mine for two years without a dash with the cluster resting on a piece of pink foam, but my zebra wood trim look real good
Mirror deletes, 80% grill blocks, wheel covers, 50 psi tires = 6% better MPG avg. over a year. Wheel skirts overcoming ethanol winter fuel mpg losses and more!
http://ecomodder.com/forum/showthrea...ead-30641.html
Old 11-21-2016, 03:29 PM   #8 (permalink)
me and my metro's Avatar
Economy Saturn - '02 Saturn L200
Anti theft device!
02 Saturn L200 5 speed- 265k miles
84 Gmc 6.5 na diesel K30 4x4, TMU
2006 Lincoln Navigator, 215k miles
Old 04-08-2018, 05:52 AM   #9 (permalink)
So things have been quiet on this one for a while... This is quite a long post summing up my experience over the last few months.
I ran an air dam for about 8 months with no significant gains. It was pretty low as you can see on the grass:
The MPGuino is dialled in and pretty consistent with my "pump maths" readings.
Without the air dam I'm seeing UK MPG varying between 25 (town) and 40+ (straignt roads in warm weather not exceeding about 40mph).
In winter I'll be lucky if I top 30-35mpg in general use. To decrease warm-up time I tried a partial grille block on an aftemarket grille. That caused a hesitant engine on light throttle. I'm guessing that is probably because it made airflow turbulent at the intake, which is situated behind the grille (but in front of the rad).
My next project will prpbably be looking at an undertray, however, I can see from Hutcho that Mercedes put a fair bit of tunnel time in on this car.
The area I think can be improved is underneat the back end - there is a bumpercover and exhaust hanging further down than anything else. It's a relativeley messy area. I will photograph the underbody next time I get it up in the air.
The underbody is reasonably flat and flow is helped by flat covers under the engine, and fuel pump area.
