Old 10-20-2016, 06:25 AM   #1 (permalink)
Campervan, eco in other parts of life
I find efficiency thinking goes into other parts of life.
Instead of buying a van I make do with a wagon. I was intending to use a tent... But instead I sleep in the back.
Is there a sleep system you've seen that is particularly efficient in this way?
Sleeping in the back for me means moving a few things out when it's time to sleep. I wonder if theres a better way...
Old 10-20-2016, 12:11 PM   #2 (permalink)
Permanent Lurker
seifrob's Avatar
Dáčenka - '10 Dacia / Renault Logan MCV 1.5 dCi (X90 k9k)
90 day: 47.08 mpg (US)
Raised bed. Basically flat box covering entire back of a car with such height as folded rear seats. Less than a feet is usually enough.
Old 10-20-2016, 01:25 PM   #3 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
A flat surface for sleeping on is important- set up your "normal use" to accomodate that.
Also:
Making curtains out of a blanket to keep heat in, light out and for privacy. Velcro helps.
Storage- a small set of drawers or small totes for personal gear.
Storage- a tote or bag for the curtains so they don't get destroyed when you're not camping.
Wiring in an outlet (or better, an inverter) in the back.
Transmission type Efficiency
