Cars with a reasonably tall choice of manual transmission gearing?
I'm trying to think of cars that have a decent choice of gear ratios for an economic manual transmission.
So far I have this: Geo Metro XFi Honda Civic CX/VX/HF/HX Honda Insight Something RWD that a taller rear diff can be swapped into. Have I missed any cars that have a decent choice of gear ratios and stand a change to get good fuel economy? |
The Cobalt XFE I believe had taller gearing.
My dad's corolla cruises at 80 at 3000 RPM with a 4a-fe converted to a 4a-f (don't ask,) but both are a slushbox.
OK, I give up. What does one do with the answer to this question? :confused:
The real reason is that there has to be more than just what I listed in the OP for cars that would respond well to a boat tail since a stock Honda civic cx/vx/hx/hf around here is like cake at fat camp, the insights are quite expensive, and the geo metros are usually already in the scrapyard. I occasionally wonder about the feasibility of building a boat tail onto a RWD station wagon and install a tall rear diff and a wide ratio manual |
H-Man if you wanna buy my HX I would be willing to let it go for what I have into it. But I think even then it would be out of your price range.
Stand a chance of getting good FE? All of them! The clutch pedal is there so you can pulse and glide easily :)
I don't have the fine motor skills or patience to deal with P&G.
At this point in time everything is out of my price range, heck I could afford the $1400 for my prizm (a bit much for the condition, but it would have cost me $100 for every week I didn't have an efficient car by the last week of August 2012, I bought it in the 2nd week of August 2012 because it was the only manual transmission car I could find on craigslist that didn't have any disqualifying traits (excessive cost, oil burning, salvage title, severe mechanical issues, no smog papers, no pinkslip, etc,)) because I worked my butt off that summer at a computer repair shop that paid flat rate. Although a friend is looking for an efficient car right now, there is a snowball's chance in hell a HX is going to go for <$2k. Quote:
My Saturn has a .605 fifth gear and a 4.025 final, 2.95 overall ratio, 2040 RPM at 65 MPH with 205/70R15 tires.
How bad is the oil consumption? I've heard that the saturns from that time burn oil, in cali smog laws make anything that kills catalysts expensive to keep running.
I had one. Gearing was so tall it was even difficult to precision park. Unless you get a super low mileage one, now they became a 10+ year old American car and that spells trouble. While your car won't spend any gas getting towed (Top Gear reasoning) you might need to get towed quite frequently and the tows are gas guzzlers. |
Knowing the overdrive ratio without knowing the first gear ratio is only half the story, as your launching (first) gear ratio will affect how tall of a final drive gear you can install and maintain some semblance of taking off or maneuvering at low speeds.
In a perfect world of picking and choosing parts, I would pick the transmission with the widest spread between first and overdrive and then adjust the actual engine to road ratios by selecting final drive gears and tire diameter. If you are willing to think way outside the ballpark…. You can get a GM NV4500 manual with a first of 6.34 and fifth of 0.732. Take an older GM car set up for a Big Block (like a corvette), swap in a Diesel Isuzu 4BD1, NV4500 Manual, 2.56 Axle, Tall Tires and you would have an efficiency machine. Back in the real world, look a gear spread, final drive ratio, and tire diameter to get the full story on a given car’s gearing. Be aware of what parts are direct swaps from other models, i.e. the axle or gear from a similar model or the same model overseas to get a better final drive ratio. Also look at where a given engine makes its torque, and if you can get ahold of one look at a BSFC chart. Or just buy a car and be happy with it. As long as you aren’t picking a car mainly based on the color, I don’t think you will make a bad decision. |
