Cats for small engines
Seems kind of like a waste of money unless you are doing exhaust heat recovery for something like prewarming water for a pressure washer application.
:confused:
Impressive.
How does it do that, given the A/F ratio controller is only optional? Does it suck in extra air to compensate for rich exhaust gases? If so, it would be a very clever device indeed! |
In finland there was a plan in the 90's you could get tax reductions if you installed a aftermarket cat. the system had a lambda controlled valve to suck in extra air for the cat. I wonder how this system works, is it a air bypass thingymajig like in scooters?
I installed a cat on my engine, and she really purrs now.
http://www.lifewithcats.tv/wp-conten...POLICECAR1.jpg |
I think the world would be a better place if everyone had a cat instead of our vehicles :3
Cats
