EcoModder.com
-   Motorcycles / Scooters (https://ecomodder.com/forum/motorcycles-scooters.html)
-   -   cbr125r improve efficiency + top speed (https://ecomodder.com/forum/showthread.php/cbr125r-improve-efficiency-top-speed-31033.html)
Spaghetti Man 01-24-2015 08:46 AM
Greetings from Australia,
Currently I am getting about
94mpg city driving at<34mph
82mpg highway at 70mph.
Top speed on level ground with a tuck position is 70mph (110km). The silly speedometer says 125km per hour at this speed.
Taking a look at the super efficient recumbent motorcycles I am wondering if any gains can be squeezed out of the inefficient design of the cbr125r.
Grant-53 01-24-2015 05:16 PM
Yes, the two things high efficiency motorcycles have in common are lower numerical gear ratios and aerodynamic body work especially behind the rider. There are several threads here and see the Craig Vetter, designer and inventor of the Windjammer fairing,Triumph Hurricane Motorcycle Streamliners and fuel economy motorcycles site for ideas.
Spaghetti Man 01-27-2015 03:30 AM
Thank you for your reply.
I did some reading regarding the vetter rifle. I would like to know what I would need tools+supplies in order to make such a fairing. If I know what I need I'll be able to set up a budget.
Any recommendations for making such a fairing would be helpful as the details are allusive.
sendler 01-27-2015 09:19 AM
The CBR125R is probably the best starting point for a fuel efficiency competition vehicle but don't make any mod more trouble than it is worth. Otherwise you will get started and never finish a huge project like that. Find a comfortable head forward riding position by laying on a big, stuffed, tank bag. Once you find a nice, high position, add a taller windshield that comes up just below your eyes. And then make a plank style luggage system or a simple truncated tail trunk which will be more aero and give you large and locking storage. Then you may be able to go up 1 tooth on the front sprocket.
I can get 90 mpgUS at 50 mph very easily without much tricky riding on my CBR250R. I got 105 mpgUS at the Vetter challenge and 136 mpgUS using EOC at 45 mph at the Green Grand Prix.
https://scontent-a-lga.xx.fbcdn.net/...f2&oe=5568E446
https://fbcdn-sphotos-g-a.akamaihd.n...a871ca74e7f266
Grant-53 01-28-2015 12:14 PM
Agreed. The biggest gains are from the tail section. A big issue is putting a foot down and the Rifle fairing doesn't allow that without cutting a hole. See Vetter's Chapter 83 on the latest developments. A bulkhead and skin structure is much easier than a fiberglass body. The shape is the thing.
Spaghetti Man 01-30-2015 11:44 PM
I went down to a local insulation business and
polyurethane costs $40.54 for 75mm x 1200mm x 600mm.
Polystyrene costs $19.80 per 100mm x 1200mm x 600mm.
Polyurethane was recommended because although the upfront costs are higher and the material is not very nice to work with the polyurethane is not destroyed by poly resins. Exoxy resins being more expensive.
I also went down to the local fiberglass supplier and although I got some advice I did not get a unit price per square meter that I wanted. I have found an ebay store that offers products at reasonable prices.
Considering that 10,000km of petrol costs about $300 the budget will not be very high. With such a low budget it is going to be difficult to figure this out.
The biggest problems to solve will me.
1) Designing an optimal fairing.
2) Transferring that design to a fiberglass mold material.
3) Once surface area is calculated and supplies ordered making the fiberglass fairing should not be impossible.
4) Sanding and painting without it costing $1000.
sendler 01-31-2015 07:51 AM
Ben has made a couple fairings, Check out his threads so you know what you are getting in to.
http://ecomodder.com/forum/380452-post120.html
http://i1338.photobucket.com/albums/...ps1d08e28c.jpg
bschloop 02-11-2015 05:29 PM
Thanks for the plug.
If you plan on removing the foam when you are finished laying up your glass you can just st use polystyrene, and wrap it in a layer of tin foil to protect and release your plug. If you want to use a foam sandwich lamination, I would recommend splurging on the epoxy, and using extruded polystyrene unless you can get the polyurethane that's used in surfboards. You could also laminate the outside with polyester resin over a foil wrapped plug, then add in foam ribs afterward using epoxy. Hope this helps.
BTW, I am planning on making my next fairing set available for purchase as soon as I've finished with developement. As it's designed around the CBR250 it should fit your 125 fine.
Grant-53 02-11-2015 10:52 PM
If the fiberglass method is too expensive or time consuming for just one unit, consider a space frame and skin construction.
Spaghetti Man 02-15-2015 10:59 PM
I ran my bike into a telegraph pole, just got out of hospital with broken leg. I now have an even better reason to make new fairings as the old ones got a bit stratched up. Will need to heal up before I go ahead with the plan.
D.O.G. 02-17-2015 04:29 AM
OUCH!
I hope your leg heals OK :) and that the bike damage is only cosmetic :D.
Pete.
Grant-53 02-19-2015 09:26 AM
Sorry to hear you were injured. Our thoughts and prayers are for a complete recovery. When you feel up to it I would be interested in the accident report as I design fairings with some crash protection. The use of aluminum honeycomb can help absorb energy and good geometry is critical. The concept of a lap belt on a motorcycle does not have much support yet.
Spaghetti Man 04-19-2015 09:30 AM
Update
1 Attachment(s)
I am walking now so I did some measurements and took out my pen and paper.
I could fit the naca 0021 airfoil to the bottom diagram, 60cm wide, 240cm long, 10cm overhang at the front and 40cm overhang at the back.
However the airfoil did not fit well to the above diagram and required stretching. I do not think the airfoil will work quite as well when distorted like this.
How can I improve this design so it is optimally safe and aerodynamically effective?
If I can settle on a design I can make a CAD model and get a quote for cnc routing (if I try to build the mold it'll look like paper mache). I am thinking of using a door rather than cutouts to maximize efficiency.
sendler 04-19-2015 10:11 AM
Very slick and close to a pure airfoil form. 200 mpgUS should be possible. Crosswinds will be tough with such a pure design. You can use a spoiler up the nose and will still probably need to vent across the width in front of the radiator and behind the engine where your feet need to be free anyway.
http://www.langleyflyingschool.com/I...l%20Strips.gif
And adding side area below the cg on the roll axis will actually help the bottom of the bike to translate over so the bike retains more of it's trail induced tendency to automatically lean into side winds. Modern race bikes have body work streamlining the exit of the front tire and attack of the rear tire right down to the point where it is just shy of dragging on the ground at full compression.
https://scontent-lga.xx.fbcdn.net/hp...55&oe=55A000E7
Spaghetti Man 04-21-2015 10:40 PM
1 Attachment(s)
I'll definitely experiment with stall strips.
I will scrap the idea of feet doors as being too dangerous at this time.
This change will reduce the shell frontal area from 0.565486686 to 0.4241150145m or 75% the size (excluding wheels). I am not sure if this makes up for the air separation caused by the leg openings.
As for increasing side area below center of gravity I am thinking of an enclosed rear wheel but beyond that I am not sure. I see what you mean about adding pressure below the center of gravity. It will cause the bike to self correct itself in crosswinds. I like that idea.
http://ecomodder.com/forum/attachmen...1&d=1429670652
I thought that extending the nose beyond the front wheel causes terrible instability which requires computer assisted controls like that seen modern jet fighters. Is this the case?
Also if I can get 0.1 drag coefficient I'll be looking at speeds of over 200kph and a fuel efficiency of 1.12L/100km at 113kph. This is much better than 125kph top speed and 3.5L/100km on the highway.
http://ecomodder.com/forum/tool-aero-rolling-resistance.php?Weight=230&WeightUnits=kg&CRR=.02&C d=0.1&FrontalArea=0.565486686&FrontalAreaUnits=m^2 &FuelWh=33557&IceEfficiency=.22&DrivetrainEfficien cy=.98&ParasiticOverhead=0&rho=1.164&FromToStep=5-200-5
sendler 04-22-2015 06:09 AM
Minimize the overhang in the front. The best self correcting behavior will be had when the center of side lift in cross winds is close to the center of the steering head. The same place you will probably end up needing cross vents. Right across the front of the radiator. It might take as much as 1 square foot of area to make it effective. The trick would be to design the vent shapes to be nearly invisible to the air when there is no pressure differential side to side, but flow with minimal resistance when there is a pressure differential.
Spaghetti Man 06-09-2015 12:49 AM
1 Attachment(s)
I have discovered the vetter rifle fairing mold was created by vacuum blowing plastic to give the terrific rounded shape. I am trying to determine if this is a cost effective method of creating the fiberglass mold.
Also I wonder if vacuum formed plastic is lighter and or cheaper than fiberglass because if it is it will eliminate the need for fiberglass.
Update: The company is incapable of producing a shell without a mold and has quoted about $3000 for the mold and $2000 for the first unit then $800 thereafter. This will not be economical as I could probably build and register a ICV recumbent motorcycle for that instead of improving my existing bike.
sendler 06-09-2015 06:17 AM
It would also be much quicker and cheaper for mass production but you are limited to the sheet size of ABS that you can buy.
Grant-53 06-10-2015 10:20 PM
I am in the process of integrating the HPV shell design program from Recumbents.com, a CFD program, and the Pepakura paper model software to make skin for my fairings.
Spaghetti Man 06-10-2015 11:39 PM
Sounds good.
I have considered developing a recumbent chassis with integrated roll cage but the red tape in Australia is too costly and troublesome for it to be viable.
gil 06-11-2015 06:09 AM
Any links, sounds interesting.
Gil
Grant-53 06-11-2015 11:06 PM
I am not real handy with links but go to the recumbent.com Forum section and select Technical / Bike Building. There is a thread on the HPV shell design. The software has provision for upright bikes as well. There is a separate thread for upright bikes. Typically a TT bike is 7/8 the size of a motorcycle. There are several CFD programs available. The Fluids6 and Autodesk use .stl files and these work (supposedly) with Perakura Design for paper models. I am just getting familiar with each.
