Champion hypermiler Gerhard Plattner
After reading about how he got 2006km on a single tank of fuel in a stock (though eco-) Škoda Fabia Greenline I looked for more info on record holding Austrian hypermiler Gerhard Plattner. Just Googling his name is enough to show that he is the recommended driver for any car company which wants to show how fuel efficient its new car is. If a certain model has broken a record or two, then Plattner was probably behind the wheel. Apparently the only mod he uses is higher tire pressure, through he does seem to prefer the eco versions with their slightly better aero. The rest is "just" ecodriving.
Worth noting are his Fuel saving tips, which may not be anything new for us, but are surprisingly extreme for tips aimed at the general public (engine off coasting, for example, or drafting at a distance). One of my favorite tips (which I can vouch for!): Quote:
convert meters to feet
30 M = 98.43 FT That's 5-6 car lengths which is a recommended minimum highway speed spacing, right? I would have thought a much closer distance would be optimal, as drafting. http://en.wikipedia.org/wiki/Drafting_(aerodynamics) Quote:
1,200 miles on a single tank is inspiring. I would be amazed if I could get half that.
Pretty good read.
DWL, 68mph, and coasting.
He recommends about 68mph on the highway (110kph). I suppose my civic would be up at about 3000rpm and would probably be in the vicinity of at least 70% load. I wonder about coasting down to 55 and accelerating with load to 68mph (rinse and repeat). Do any of you do this? You would yield an average speed higher than 55 for sure, probably well over 60, and you might reap FE benefits? EOC is a bit dodgy on the freeway. Does anyone do that? I am suggesting neutral coasting, engine on.
I used to coast in neutral, but now I coast in gear (I think the fuel cuts off when in gear versus a little fuel is used when in neutral to keep the engine on). I'll turn the engine off and coast in neutral to a stoplight (key to on for lights and steering). 1/3 the time I'll have to bump start to go when I get to the light, 1/3 I'll be sitting for 30 seconds+, 1/3 I'll come to a stop and have to start in less than 10 seconds (that ones the bummer). Right now I'm pretty close to 30 mpg(combined) with my Vibe GT. Edmunds says 22/28. Before any hypermilling techniques I could get her down to 20 (or less!) I just had a couple of draging brakes fixed so hopefully it'll go up a bit more. |
@Cali98Civic: What surprised me was recommending that the engine speed should be in the 2k-3k rpm range without adding that this is for a petrol engine. This is still highish, I read that the range should be more like 1500-2500rpm, while a diesel should stay below 2k rpm. As for the high speed (110 km/h), I try keep 80-100 km/h on the highway, but this may not suite everyone. He's trying to get to the general public, so 110 instead of the 120-150 that most people are doing is easier to get through than recommending 90. Also, when he does his eco-runs he may be aiming for a relatively high average speed, and bumping it up on the highway allows him to go slower in traffic, which probably works for him.
"If possible you should step on the gas on the steep counter-hillside. And then, when you are driving uphill, don't change the position of the gas throttle anymore; even if you slow down a bit. Accelerating when driving uphill really wastes a lot of fuel! One of the reasons why it is very important to think ahead when driving."
***** Wow. And here I thought I was the only one who did this. |
