Champion hypermiler Gerhard Plattner
After reading about how he got 2006km on a single tank of fuel in a stock (though eco-) Škoda Fabia Greenline I looked for more info on record holding Austrian hypermiler Gerhard Plattner. Just Googling his name is enough to show that he is the recommended driver for any car company which wants to show how fuel efficient its new car is. If a certain model has broken a record or two, then Plattner was probably behind the wheel. Apparently the only mod he uses is higher tire pressure, through he does seem to prefer the eco versions with their slightly better aero. The rest is "just" ecodriving.
Worth noting are his Fuel saving tips, which may not be anything new for us, but are surprisingly extreme for tips aimed at the general public (engine off coasting, for example, or drafting at a distance). One of my favorite tips (which I can vouch for!): Quote:
convert meters to feet
30 M = 98.43 FT That's 5-6 car lengths which is a recommended minimum highway speed spacing, right? I would have thought a much closer distance would be optimal, as drafting. http://en.wikipedia.org/wiki/Drafting_(aerodynamics) Quote:
1,200 miles on a single tank is inspiring. I would be amazed if I could get half that.
Pretty good read.
DWL, 68mph, and coasting.
He recommends about 68mph on the highway (110kph). I suppose my civic would be up at about 3000rpm and would probably be in the vicinity of at least 70% load. I wonder about coasting down to 55 and accelerating with load to 68mph (rinse and repeat). Do any of you do this? You would yield an average speed higher than 55 for sure, probably well over 60, and you might reap FE benefits? EOC is a bit dodgy on the freeway. Does anyone do that? I am suggesting neutral coasting, engine on.
I used to coast in neutral, but now I coast in gear (I think the fuel cuts off when in gear versus a little fuel is used when in neutral to keep the engine on). I'll turn the engine off and coast in neutral to a stoplight (key to on for lights and steering). 1/3 the time I'll have to bump start to go when I get to the light, 1/3 I'll be sitting for 30 seconds+, 1/3 I'll come to a stop and have to start in less than 10 seconds (that ones the bummer). Right now I'm pretty close to 30 mpg(combined) with my Vibe GT. Edmunds says 22/28. Before any hypermilling techniques I could get her down to 20 (or less!) I just had a couple of draging brakes fixed so hopefully it'll go up a bit more. |
@Cali98Civic: What surprised me was recommending that the engine speed should be in the 2k-3k rpm range without adding that this is for a petrol engine. This is still highish, I read that the range should be more like 1500-2500rpm, while a diesel should stay below 2k rpm. As for the high speed (110 km/h), I try keep 80-100 km/h on the highway, but this may not suite everyone. He's trying to get to the general public, so 110 instead of the 120-150 that most people are doing is easier to get through than recommending 90. Also, when he does his eco-runs he may be aiming for a relatively high average speed, and bumping it up on the highway allows him to go slower in traffic, which probably works for him.
"If possible you should step on the gas on the steep counter-hillside. And then, when you are driving uphill, don't change the position of the gas throttle anymore; even if you slow down a bit. Accelerating when driving uphill really wastes a lot of fuel! One of the reasons why it is very important to think ahead when driving."
***** Wow. And here I thought I was the only one who did this. |
You don't have to get into the stupid-zone to get great mpg gains. All you need to do is enter into the disrupted airflow and low pressure zone and you make impressive gains. |
Thank you very much for this article Piwoslaw. You always have good information to share with the group !
BTW, I find it amazing that the roof top luggage box was left on when he did one of his runs. |
If someone fills the gap then that is usually because they are lane changing to exit or enter a motorway. My attitude is let them do this, it means you concentrate on them whilst they concentrate of getting to the outside lane asap and may not be watching you. And it means people can merge on/off without you braking. |
One's for sure: doing 68 mph gets a much lower mpg than doing 55! Even Gerhard can't beat physics...
Thanks Piwoslaw,
I think that's the best paragraph is: Quote:
constant travelling speed versus mileage
Shooting for Guinness World Records one has basically to figure out at which speed a specific car gets the best mileage. With most cars that speed is somewhere between 60 and 90 km/h (37 - 56 mph). Now, european trucks generally travel at 89 km/h (ca. 55 mph, yes they usually exceed their 80 km/h speed limit by 10+ %). Hypermilers would have to travel that speed in order not to disturb traffic flow on the RH lane. Yes, it's a sport and a lot of concentration is needed to shoot for best mileage. It's a sportier way of driving than putting 'the pedal to the metal'. As Gerhard is generally averaging 75 - 80 km/h on his record drives, his highway speed would be closer to 90 than 110 km/h. Each km/h above 90 will reduce mileage by ca. 1% |
This is old.
Gerhard does it once again. On CNG this time.
Over 2600km on less than 100 euro worth of CNG
Using a Skoda Citigo CNG - a half-brother to the VW up Ecofuel (and my GasDwarf) - Gerhard Plattner has driven 2619km from Vicenza, IT over the Alps, through 9 countries all the way to Stockholm, SE , merely using 2.39kg CNG / 100 km (NEDC : 2.90kg/100 km) and costing less than 100 euro overall . Doing it on 100 euro (max) was the challenge - but he still had 9.93 euro in change and enough gas to go another 300km or so ... Best tank : 2.04kg/100km All CNG must have been H-Gas (CNG with High caloric value) though, to achieve this kind of numbers. Looks like I have a long way to go ... even if we account for the lower energy in L-Gas (CNG with Low caloric value). OTOH ... I've done 7150 km on 50 euro (CNG and 2 US gal petrol) :cool: Even if only because I'm about 1/3rd into the 500 euro CNG credit that I got from DATS24.be - the leading CNG supplier in Belgium - when I bought the CNG up! :rolleyes: |
What I'd more interested in, is HOW he got that low a gas consumption.
But I'm not sure VW / Skoda even want to go there ... They claim the car wasn't modified, but I'm pretty sure he ran considerably "higher than recommended by Skoda" tyre pressure :p |
What I find that if I come too close (less than 10 meter) the air becomes very turbulent. That reduces aerodynamic efficiency and increases resistance, so much so that when I leave the car in cruise control mode (which in eco mode responds slow to lowering speeds) makes it lose speed and self corrects the distance. The benefits from slipstreaming at a distance are small, but noticeable. But low speed is the real winner. Most of all the presence of the semi provides a legit reason to drive slower than the rest of traffic, which is eager to overtake that semi anyway. Drafting close by would only work if you draft really close, as like on the towhook. Needless to say that is not a safe driving strategy. |
Riding with a higher tire pressure does not count as a vehicle mod. Everybody can run his car at a optimum tire pressure for better fuel economy.
Gerhard Plattner most probably is the world's most experienced longtime hypermiler! |
Let the other drivers enjoy their rat race. Even if they win, they're still rats. :) |
