Changing body work to improve aerodynamics?
Recently I've been looking more and more at the aerodynamics of my car and it had me wondering about changing the body work on it. Mainly the front bumper.
I circled the areas I would change by filling them in and making them flush with the rest of the bumper http://i1024.photobucket.com/albums/...ps4el1rdr3.jpg My thinking is probably flawed, but it seems like the air would go around the car smoother if it wasn't being forced into 4 pockets first. What do you guys think? |
Did you see this...??? http://ecomodder.com/forum/showthrea...deo-30124.html The video at the 1:58 mark shows a similar placed hole being important for wheel airflow. Are they holes or pockets ? > |
On mine they are completely solid. No airflow going through
Looks like the vid is the new body style
Even for the old style, if they are shaped like pockets with a solid backing, they will be forming their own circulating air cushion that's designed to push air outboard of the front wheels.
Note that most manufacturers nowadays have abandoned the circular foglight holes for square ones or holes with a tall vertical element in front of the wheel well, for just this effect. You'd be better off doing a partial grill block... especially seeing as how the Mustang's grille and hood form a gigantic parachute... :D |
Have you looked at http://ecomodder.com/forum/showthrea...per-30070.html?
Working with only the bumper and a grill block he was able to gain 0.04 on the Cd. |
I've seen that also. And I've done the grille block thing. I'm just curious if filling in the 4 pockets that I circled would help or not
I'm not even sure why ford added those 4 pockets, except for fog lights on certain v6 trims and the gt/cs trim. But even with those fog lights, they only use the top pocket
http://i1024.photobucket.com/albums/...psetbkdies.jpg Seems like it would've been better to use round fog light pockets like they do on the roush and the gt500 http://i1024.photobucket.com/albums/...ps7o7oaiqh.jpg http://i1024.photobucket.com/albums/...psps3z4tni.jpg |
I see them as a style element pulled from the 1970 Mustang front end mixed in with a Shelby style front end. ( I love that design )
http://www.cqrbps.com/wp-content/upl...--1024x576.jpg I'm guessing that filling the pockets will do little to nothing for the aero. If anything, they might serve as an air curtain. If you do fill the area, you could use a clear lexan material like that used to fill the light sockets on the Viper GTS. You have a really nice looking car. http://www.bjmotors.biz/images/inven...8/large_01.jpg (Viper GTS - man what a fine looking machine !) |
Who just made fog light covers? I thought they looked great, except for the tape!
Here are the ways that it has been done on land speed cars : https://www.fordracingparts.com/must...s/img_0713.jpg https://www.fordracingparts.com/must...ting_ready.jpg |
I did a little CFD work in a amateur grade program on your car, but still came up with some interesting results when i blocked the bumper 'pocket' on one side and left the other stock.
Apparently, there is some 'aircurtain' effect going on. ( Note the pressure difference in the front of the tire on the unblocked side. On a side note, i got the approximate Cd down to .28 by blocking the upper grille flush and closing off 3/4 of the bottom. This is the stock side : http://i877.photobucket.com/albums/a.../unblocked.jpg And this is the blocked side : http://i877.photobucket.com/albums/a...sideview-1.jpg There is more stagnant air on the blocked side ( the dark blue ) http://i877.photobucket.com/albums/a.../pressure1.jpg |
pockets
The pockets are in a very favorable pressure gradient and surrounded by large radii also within a favorable pressure regime.
I suspect that they make little difference to the air.Just little pools of dead air with active flow skimming over. |
