Cheap Fix for a Tranny line?
Thread extracted from an off-topic thread
The Patient: SkuttleButt, a 96 Ford Taurus sedan. The Ailment: Leaking upper transmission line (right at the nut). The Symptoms: Requires about 2 gallons of transmission fluid a week. More or less depending on actual driving use. Examination Done: Visual examination with futile attempts of wrenching. Current Treatment: Drinking plenty of fluids. Quote:
i feel much better now. |
What the devil is standing between you and fixing the dang thing??? :confused:
I get an allowance from my wife. I'm only allowed to spend that much a paycheck.
Right now you might say http://members.lovingyou.com/images/smilies/bash.gif or http://members.lovingyou.com/images/smilies/doh.gif but to be honest, it's a GOOD thing that i'm on an allowance system. Or else we'd be in the poor house. I have brains with money, but she has the restraint that i don't have. |
Where's the "brains" in pouring tranny oil all over the place?!?
You could have had that thing fixed ten times over by now for the price of the oil you've wasted. :rolleyes: Don't look for any goop, slop, tape, stickers, mantras, or anything other than a REPLACEMENT LINE. It ain't rocket surgery and it ain't gonna get better by itself. As Dilbert would say: "GAAAAAAAAAA!!!" |
math is not my best subject
Doing the math: g=gallon w=week $=duh 2g x 104w x 6$ = $1248 I have to agree with Frank on this one. Almost. The shop My friend owns would have charged $225 for the repairs. Provided it is actually a cracked line. $150 parts + $75 labor. I asked him. so you could've had it fixed 5.5 times by now. OR Fixed it once and had $1000 left over for one Heck of a Bowl Party. or, buy a used forklift, used Metro, and related parts to build your EV. On a different note; I understand the need for an allowance. Some of us,(me too:o) have trouble with self control. I try whenever possible to justify with figgers, my need for a new tool or part or whatever. Hence I have no SG, yet. But I'm working on it. Can't use it on a 93 Metro, SWMBO won't change driving habits. Period. 2 speeds: Haulass & Stop. Thank God for ABS. "Smell that--- that's the smell of goood brakes," "?Smell It? I'm sittin in it" I haven't made my point with the numbers yet. However I may be able to make it using my daughters car and boosting her mpg. I have to figure fuel savings over initial cost over years to recover funds. So Fix it already. I'll shut up now. S. |
Take no offense here please , but does your wife work in upper management?
We have the same problem at work and its been goin on for yrs. We go thru a 330 gallon tote of hydraulic oil,in at the max every 10 days because 2 machines manage to empty it out every 8 hrs. You might say recycle but where they are leakin it mixes with the coolant and produces large amounts of tramp oil in the coolant,(another problem). Don't know why but they just don't seem to think its worth the money to send maintenance over there to fix it. BTW I think you could have bought the line and the line wrenches for the cost of 2 weeks of tranny oil at that rate. |
-Transmission Leak -No breaks (ok, maybe 10% of what they should be.) -Oil Leak (sorta fixed) -rear of the car has been shorted 2 feet (but only in the middle, damn gas pole) -2 power windows don't work. -Dash lights don't work. (well, one does. It says "Check Engine". I checked, It's still there.) -4 different brand and size tires (only 3 are bald though!) -Dead headlight (ok, it's not the bulb. it's the mount. this causes the light to vibrate and burn out about every two weeks) -on a good day it shifts in both OD and D. on a normal day it only shifts in OD. -There was a fire under the hood before i bought it so No insulation under the hood. (don't slam the hood down too hard - it'll short the battery) -Radio was stolen. now it's a 2AAA batt hand held radio. -When the breaks are working don't stop too fast - the back seat will fly up and hit the back of the front seats. -When you turn, the power steering says "Yes! No! Yes! No! Yes! No!" and tugs at the wheel in a pulsing type fashion. that's off the top of my head... as you can tell i don't really know that much about cars. |
Spelling either :rolleyes:
Know! Eye Kan't Cpell!
Breaks??? BREAKS?!? Tell me you didn't marry your sister.
Lol!
you still havn't tried to fix the A/C!? It's like $9.99 for one can of refrigerant (how much I used) and kits that have one can and gauge/refill hose is like $19.99. It's really easy to do too, unscrew the valve cap, screw onto A/C valve (located usually on the A/C pump, if hard to get to there's usually a second one on the A/C line). And recharge the refrigerant until correct pressure is acquired.
Here's one can, you can get them at wal-mart. Here's what a Recharge Kit looks like, it has the hose you need to attach to the valve, and a gauge on the hose. They go anywhere between 20-25 dollars at wally-world. This is more of like what I've seen at wally world, except it's got a smaller 13oz. can with it, and is also 10-15 dollars cheaper. 22oz. can do a few vehicles, so 13oz. should be enough. When You do it, have the A/C on high, feel how cold it is before you do it, then while you're recharging, notice how often the A/C pump kicks on and off, it should (instead of engaging the clutch on, then off, then on, then off,) keep a constant on, with an occasional kick off (you're keeping the A/C on high, max cooling while recharging), then after pressure is optimum, go inside and feel the air temp. it should be cold again. Back to tranny, fix it, and stop spending so much freaking cash!!! then sell it, or turn it into an EV. If you do it yourself you can save even more money than paying for labor. |
The AC is the other car that i don't drive (big ben) LOL.
that's $10.00 i can spend toward my EV! :D (i told you, she has the restraint) I can't do a conversion on Big Ben because there is some minor rust, and i learned from Metro's Forkenswift post about how much bigger rust can be once you get into it. I'm not doing a conversion on SkuttleButt because of all the other problems wrong with it. I can get a $200ish 'donor' car with less problems for converting. Btw, on BigBen, i think it has a bad Alternator. I just replaced the battery and the batt light stays on when i start it up (once a while because i hear it's good). Because of the last batt problem it had, i think the Alternator isn't recharging the batt. My personal preference is I'd rather just ditch both cars and do an EV on a donor car. I should of named this thread "Take a shot at the Chicken" but I'm enjoying it. :D |
Considering the leaky fitting you'll probably need a new line. However I've seen shops cut the bad line a short distance from the bad end and splice on a new end. Saves you from having to find a source for the complete line and pay the price - just the cost of the short bit you're replacing. Also if you want to have another go at it, get a wrench that will really get in there and see if you can tighten it. Maybe you can use a short stubby wrench or a crow's foot "socket" on a 3/8" drive set. I made a stubby wrench by cutting off part of a regular wrench handle. For this job you probably need a flare nut wrench, get a cheap set and shorten the handle if needed. Dremel with a reinforced grinding wheel did that job nicely for me. Cheapy no-name "Dremel" grinder has turned out to be one of the most useful tools I ever bought. There are also wrenches with heads bent at a sharper angle than usual. I'd think you or a friend could make one of these too. Might need some heat but probably could be done. |
Since he's not serious about it, he may as well find some block-letter stencils and paint "Valdez" on the front fenders.
obivously hes more interested in trying to kill someone with a car that doesnt stop, doesnt turn, tries to set itself on fire, and creates its own oil slick that the rear tires will lose traction on in the one time hes able to avoid hitting something. :shakeshead:
When I was talking about fixing the A/C, You said you almost sold it but they didn't buy because of the A/C, you gotta spend money to make money, and think about how much more money could go into that EV if you spend $10 on Freon, then sell it for more.
Good luck fixing that tranny tho :p |
spliceing on a new short line is no big deal. i'd say you need a one factory end from any parts store.. better use a tube cutter. cut a end off. from any hardware or parts store get a tubing connecter of the right size. get a guy at the store to show you haw to put the ends and round parts together. don't mess up the cuts and cut too long. not too short. before all that you may want to put the front end of the car up. use a spray solvent to clean up and run it to see for sure where the leak us. making very sure it will not fall or drive of the blocks.
