Check transmission light
More details to follow.
it would be hard to give fewer details....
Its the wheel speed sensor.
I had my girlfriend come over and I used the Ultragauge. It showed P300, P301, and P302 as pending, but I thought those were leftover from Bacon. It showed P1399 and that seems to go with the 300s, but I cannot find anything relevant to the check transmission light. Whenever I do a keyword search on any result that comes up, it does not find "transmission!"
So, going to try to study for my test... |
What type of car is it and what year?
This is Chorizo, my Civic. The light was blinking when I left drill Sunday afternoon and, not knowing where would be open, I decided to carefully drive home and stop at an auto parts store for some bad advice. When the light stayed on, even after rebooting the car, I pulled over, not realizing that the transmission fluid did not have a dipstick, but not knowing what else to check. It was only later that I realized that I should have checked my parking spot for leaks.
I was really trying to get back to studying, three days of drill and then two tests for which I simply did not have time to study. I hope that I did okay on them. My girlfriend was over, so I pulled my Ultragauge from Bacon to see if I could get any useful information. It showed misfire codes, which I thought were from my Forester. I was just going to not drive until after my tests, and then straight to the nearest shop, but someone suggested resetting the codes, which I did, and then realized that the check transmission light was off, so I drove 25-30 miles and Chorizo drove fine, no lights, error codes, weird noises, or anything. So glad that I was worried and distracted over nothing. Strangely, my Civic HX showed the same highway mileage as my Forester. That just is not right. |
Check transmission light in a manual car? I'm guessing the light is for the CVT HX.
Most likely ignition coil/distributer problem causing all 4 cylinders to miss intermittently. Check the plugs and see if what brand thy are and if they are worn.
Was it rainy/damp when the light was flashing? The engine light flashes for a severe misfire.
