Check your brake lights!
It was a "routine" traffic stop... the officer had been following me for some time, of course, and noted that I hadn't used my "brakes" even one time, including slowing for traffic lights, etc. though a busy part of town... of course, using brilliant deductive logic, he decided that my brake lights MUST be blown out or inop... so he pulled me over. When I saw his lights come on, I was going about 30 MPH. It takes me only a short time to stop from 30MPH once I shut the engine off, so, once again, I didn't use my brakes - "confirming" his suspicion. Believe me - I was more than a little annoyed with this particular officer by the time all was said and done, and I may have gotten slightly belligerent with him and his insistence that it's absolutely impossible (!) to stop a vehicle without applying the service or parking brakes. :rolleyes: (It was also decidedly wasteful of my time to explain to the officer that parking brakes don't turn on the brake lights, due to the fact that they're designed to hold the vehicle in place while it's stopped and parked... .) So, after explaining (again) exactly what I did, and showing him that my brake lights were, in fact, operational, he reluctantly let me go with a "warning". I'm not really sure what he was warning me about, because it was clearly a verbal warning. I didn't even get a piece of paper, so I don't have his badge number or anything... Wish I did, cuz he was a mouthy one... I'd more than likely have reported him to higher authorities. |
Christ -
Hee hee. I would have tapped the brakes at the very end so that he knew his argument was moot before he walked up beside my car. CarloSW2 |
I just turn the engine off, and start walking the transmission down through the gears. If I come up a little long on the engine braking distance, THAT'S when I use my brakes. It doesn't happen often, because I normally don't need to come to a complete stop anywhere. When the light turns green, I turn the key back on, and begin re-accelerating back to the speed limit. I try to time the lights, but around here, it's killer at times, especially during peak-traffic times. I guess if this is going to keep happening, I'm going to have to start using the brake pedal a little bit again... that's a shame, though - more electrical load. :( |
I wasn't really sure why the cop was pulling me over, so it never occurred to me to show him that my brake lights did, in fact, work. That's one of those times where a little more information probably would have eased the situation a bit, eh? |
Chirst -
I have a hunch that I am usually followed because of my small side-view mirror. Once they see all my other mirrors, they back off. CarloSW2 |
Cops can be .......
but it is wise to choose your battles... |
:thumbup: last fall, I got hit in the back at a redlight, on a steep hill...stupid driver didn't even acknowledge my lights...goes to show, with or without, something stupid can happen. never count on anything..and stay alert. |
...some of the hybrid cars use "deceleration" lamps (yellow?) to warn following traffic that the vehicle is indeed slowing down towards a stop even though the brakes might not be activated yet.
One thing that does throw me off is these cars that have rearward DRLs. They just look like someone is riding the brake. |
just hook up a vacuum switch to your brake lights..
I once saw prototype Chrysler Rapid Transit cars that had a red, orange and green stop lights on them.. green was when it was accelerating, orange was when slowing or downshifting and red.. yeah.. adapt something along those lines that only comes on after a few seconds of being in vacuum they the brakes come on.. |
I see quite a lot of signs about "No engine braking within city limits", but I think that is strictly a noise issue...
Yeah, that's for trucks and their "Jake Brakes."
I wonder if you can fight being ticketed for no visible brake lights if you stop at a stop sign, and from a distance it might appear that you performed a California (rolling) stop... it could very possibly look as if you did not come to a complete stop or stopped at all. |
I'm sure every State/Province is different, but this may cross-apply to the average vehicle (and likely be legal without law enforcement knowing about it :rolleyes: ) Perhaps 2 sets of brake lights could do the trick -- one pair for decel (using the vac idea) and then the standard set. RH77 |
I would go with a push button mounted to the gear shift for my thumb.
And how about if the sign said no Jake braking and if you are a trucker and don't have the Jacobs brand engine brake but a different brand. I guess that would technically be ok too. |
Hi,
The thing to remember is that you do not lose anything to also lightly use the brakes, while using the engine to slow the vehicle. This lights up your brake lights, and it keeps the rust from forming, without losing the fuel cutoff. |
I haven't actually verified that, though. |
Well, I'm glad I am not the only one, I've been stopped 2 times for this.
First time cop was looking for an excuse to pull over a drunk driver (which he was "100% certain" that I was). I used the brakes to stop though, and he wouldn't acnolage that my red brake lights were lighting up his cruiser when I applied them after he told me that they were broken. Second time was ok cop pulled me over, and politely told me that my brake lights were going out, he had followed me for X miles and the brake lights never went on until he stopped me. My obvious response was that I probably hadn't used them in that time period. |
