Old 12-19-2010, 09:19 AM   #1 (permalink)
jackbauer's Avatar
Headway traction pack
Recently decided to take the lithium plunge and decided upon headway 16ah cells. Here's an initial video on the plan thus far:
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 12-20-2010, 10:04 AM   #2 (permalink)
What made you want to go with the headway cells vs TS or other prismatic type cell?
Old 12-20-2010, 03:14 PM   #3 (permalink)
jackbauer's Avatar
I got a good deal on a quantity of the 16ah cells. Price i couldnt refuse I was going to use them for the motorbike but decided to take the plunge and add a few more and make a pack for the car.
www.evbmw.com
Old 12-26-2010, 10:42 AM   #4 (permalink)
jackbauer's Avatar
Figured it was time to work off some of that turkey today so decided to do a few hours in the workshop. Pictures tell the tale. The company that was supposed to supply the aliminium tubes for the corners let me down badly. Not wanting to be held up any further i improvised spacers by parting off some 20mm pvc electrical conduit on the lathe to 200mm. Will do the job until the aluminium eventually arrives.
Oh and Merry Christmas everyone
ID:	7566   Click image for larger version
ID:	7567   Click image for larger version
ID:	7568   Click image for larger version
ID:	7569   Click image for larger version
ID:	7571   Click image for larger version
www.evbmw.com
Old 12-27-2010, 05:23 PM   #5 (permalink)
jackbauer's Avatar
Bit more progress :
www.evbmw.com
Old 12-29-2010, 06:21 AM   #6 (permalink)
jackbauer's Avatar
Just this morning finished the 72v section. Will be testing in the car soon.
ID:	7577   Click image for larger version
ID:	7578   Click image for larger version
ID:	7579   Click image for larger version
ID:	7580   Click image for larger version
www.evbmw.com
Old 12-29-2010, 07:14 AM   #7 (permalink)
Looking good!
What are the overall dimensions of the pack all put together?
Old 01-03-2011, 02:20 PM   #8 (permalink)
jackbauer's Avatar
Headways are in ...............
www.evbmw.com
The Following 2 Users Say Thank You to jackbauer For This Useful Post:
richtate (03-15-2011), SoobieOut (01-03-2011)
Old 03-12-2011, 03:08 PM   #9 (permalink)
Jack,
I recently went through your BMW build site....nice job. I was wondering if you could provide some information on where you got the motor that you are using. The specs on the data plate would fit my application very well. Also, what gear do you typically drive your car in?
Thanks...
Rick
Old 03-12-2011, 04:19 PM   #10 (permalink)
jackbauer's Avatar
The motor came from a 72v mitsubishi 4 ton forklift. I use 3rd and 4th mainly and 5th for motorway driving.
www.evbmw.com
