Chevy truck rear bumper build
4 Attachment(s)
The pickup truck bumper I have on there right now is starting to get kind of rusted out. It always had a few things I didn't like about it. The aero dynamic profile is like a metal parachute and its thin stamped chrome plated sheet metal. The chrome is slippery when wet. This build will not have any of the spy car stuff like the front bumper here http://ecomodder.com/forum/showthrea...ild-33370.html
The metal parachute.. http://ecomodder.com/forum/attachmen...1&d=1459222999 http://ecomodder.com/forum/attachmen...1&d=1459222999 The fit wasn't perfect but I liked it enough to use it. No it was not a direct bolt on, I had to modify the suburban frame with my plasma cutter to make the bumper fit. My requirements are: Make it heavy, since this is a rear wheel drive only vehicle Stainless steel diamond tread, because that's what I like Build it to the existing frame as much as possible, modify the frame as needed Build it around the class 4 weight distribution hitch Bolt the bumper to both the frame and distribution hitch for ultimate strength Bolted not welded to the frame or hitch so I can remove it for modification or repair. Aerodynamic profile better than the current disaster Additional reverse light Place for license plate License plate light Storage box for flat 4 connector This is kind of what I want it to look like, http://ecomodder.com/forum/attachmen...1&d=1459222999 The class 4 hitch. http://ecomodder.com/forum/attachmen...1&d=1459222999 I can make it fit close to the body and have it look a little better and be a little more aero. What do we think would make the best shape to put on the outer edges of the bumper? Projected start date is august. I am running low on 1/8 and 1/4 inch thick diamond tread and don't want to pay retail prices for it. This way I have plenty of time to iron out the design and collect materials. |
You could screw or rivet a flat sheet of plastic (PVC, ABS or polystyrene) to both the body and the bumper.
For that matter, sheet metal with folded over edges would also work. If you want to get fancy, a foam plug covered in fiberglass would be the slickest. EDIT: There is this 911 project of interest (welded aluminum). http://forums.pelicanparts.com/porsc...1s-1977-a.html http://forums.pelicanparts.com/uploa...1401877133.jpg |
That guy likes aluminum about as much as I like stainless.
Making the transition between the body and bumper like they did on that Porsche. I am building a whole new bumper, not modifying the one in the picture, it has a few holes rusted in it. I sand blasted the scaly rust off 4 years ago and painted over it and that left the steel pretty thin in a few spots and the water found a way to get back into the metal. |
new design
I'd consider making a deeper bumper with the bottom aligning with a future 2.5-degree diffuser projecting off the bottom of the rear axle line.Rocker panel extensions behind the rear wheels would blend into the deeper bumper.
Since this build will be made with much thicker stainless joints.
On the front bumper build the heaviest joint was just a 1/4 to 1/4 inch butt weld, my little 105 amp home made tig welder was just barely able to weld that. The heaviest corner joint was 1/8 to 1/8 and the 105 amp tig was able to weld this with ease just from one side. On the rear bumper I will be welding at least 1/4 to 1/4 inch almost every where. But could be as thick as 3/8 or 10mm, just depending on what shows up at the scrap yard, I am not paying retail for 1/4 inch stainless diamond tread, it is rather expansive and I am rather cheap. And I am going to weld both sides for maximum strength. Getting into that 90 degree corner is going to be kind of tough, its going to be really difficult if the machine I use cant provide enough power to melt the 2 sides of 1/4 inch or thicker plate. So I am eyeing my 230 amp craftsman welder to be converted to tig. Really the only thing keeping me from using the full power of the craftsman is my air cooled WP-17 tig torch, its only rated for 150 amps DC and 115 amps AC. I have read the WP-17 torches fail spectacularly if you give them more than 200 amps. I am too cheap to blow up my perfectly good WP-17 and have to replace it and still have to buy an appropriate torch. Also 105 amps AC seems to be the practice limit of what the WP-17 can handle, it heats up quick and burns up collets with ease. So I am thinking I will get a WP-18 torch. Its water cooled and rated for 350 amps at 100% duty cycle and 250 amp AC 100% duty cycle. Then use my http://ecomodder.com/forum/showthrea...ing-32417.html cooler-pumping unit as my torch cooler because I am cheap. I am not spending hundreds upon hundreds of dollars on a torch cooler. Why a 350 amp 100% duty cycle torch on a 230 amp machine? Because I may want to combine the DC outputs of both welding machines, which could add up to right around 350 amps and 230 amps AC is awfully close to the 250 amp AC limit. |
Some pictures , with a 1'ruler in pictures for scale references, burb without the bumper would help the community to provide useful design ideas.
I'm extremely interested in this build as my'91 Dodge D250 has the same problem bumpers sticking out 3-5"past the sheet metal. Gumby stay flexible. |
1 Attachment(s)
This is what I would like to avoid.
Happened to a 10th generation 3/4 ton suburban. http://ecomodder.com/forum/attachmen...1&d=1464148922 I believe this was a class 3 hitch, I have a class 4. |
Oil pan did the frame fail or is that a bumper mounted receiver class 1-2? What ever the case, it was eather in an accident or a gross over load for no Wight distribution/ load leveling hitch. Win I worked at U-haul 1999-2000 I had a customer with a cl4 in this condition. His wife rear-ended his travle trailer with wight distribution hitch and folded the hitch ,bumper, and frame under the back of the truck. Looked just like that.
Well that would be my luck then.
1 Attachment(s)
Here is another one.
This one comes with a little back story. The guy said he accidently put about 4,000 pounds of tongue weight on his pickup while loading a trailer. Oops. http://ecomodder.com/forum/attachmen...1&d=1464243074 |
1 Attachment(s)
Alright I have been back for a few days and hitting up the scrap yard and added another 70 to 80 pounds of stainless diamond tread and flat plate to my hoard.
I am not really finding any 3/8 or 10mm thick stainless diamond tread of flat plate. Mostly its 1/4 and 5/16 inch. In the picture is all my 1/4 and 5/16 stainless, I still have some 1/8 inch but I am going to try not to use that. http://ecomodder.com/forum/attachmen...1&d=1471568523 I think I have enough to at least get started. Plan is still to make it tough to where when I back into something or something backs into me it gets destroyed and later all I have to do is buff the paint, plastic or blood off. And bolt the bumper to the frame and hitch. Looks like I am just going to have to use 1/4 and 5/16 (6mm and 8mm). Welds will be left raw, only buffed with a red 3M pad scrub pad and maybe a light bead blasting. I just ordered that 350 amps water cooled WP18 torch earlier today. When its 100F out and you're in the sun the air cooled torch don't air cool very well. |
I'd think an flat end plate, like on a ricer wing but upside down and smaller.
It could align with the trailing edge of a future Turnpike-cruiser type fender skirt. |
https://www.etrailer.com/static/imag...u44920_800.jpg Your hitch maybe in the way. For this type of bumper I had a different hitch for evry chassi 'make,model of pickup. When I worked at U-Haul Merced, California back in 99-00. Or just come through the bumper with the receiver for a clean finish on the bottom. ------ Question Is the shape of this low center more lending to maintaining a shallow assent sub3° as the diff would match the extra low center, and the axel hight matching the outer hight? (this you can adjust for ,as your the desiner) Would this shape rear belly pan also lend to Boat tail by nature of straight lins low point to low point. As any quality brainstorm you must also identify the pit falls ... Boat tailing is counter productive for a dedicated tow rig as you pull more air in closer to the center line of a trailer thats often wider than the truck. Resulting in an increase of frontal area, such as a 102" wide(for those considering a similar project on their dedicated tow rigs). Dreem big chisel down to reality. |
Yes something like that, its kind of like the current pickup bumper I have that's rusting out. I may skip the center concave section since I don't need a place to put a ball hitch.
If I were going to put a ball hitch I would insist on at least 3/8 plate, but I don't have any. |
bumper drop
I'd consider a flat section across belly back there,then do a fairing for the differential's pumpkin if it sticks out in the airstream.
Got the 3/8 flat plate.
Still waiting on the tig torch. |
