02-05-2012, 10:51 PM
Looking at a 2000 Insight tomorrow!
So, I saw an insight pop up the other day at the local honda dealer.
2000, Silver, 5-speed, 138,000miles...Asking price of $7,995
So I hope I can talk them down to $7,000 because that it a bit high if you ask me. What should I look out for? Should I be concerned with the battery packs going bad?
I actually gave the car a look over today but, the lot was closed. Seems to be in good shape but, s few small things here and there. Tire tread is a bit low, some marks on the back bumper, and Ding on the one door. I was also surprised to see a cassette player in this "futuristic" car...haha
02-05-2012, 11:12 PM
It is great that you are looking for a so eficient hybrid car. The honda insight is probably the best ever produced. If you could take some pictures it would be awesome
It think that 7k is a little bit high for 2000 , maybe 5.5 6k would be reasonable.
You must absolutely check the battety pack, it would be sad to have a dead one.
I will surely follow this thread
HMQC
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
02-05-2012, 11:23 PM
Nice one, thank you. i'm planning to get one some day but don't worry it won't be this one
02-06-2012, 06:20 PM
update:
The dealer said on the phone that the transmission is messed up and the batteries aren't working. Seemed like they weren't looking to sell it. So I didn't look at it today. No big deal because I found another Insight on craigslist...
So, the one I am checking out tomorrow (private seller)...2002 Red, 5speed, 200,000miles, Battery not working! Asking price $3,500
He was telling me how a lot of insights have messed up 1st and second gears. But, they are fine on this one....He is a total insight nut (I think he owns 3 and is doing an engine swap on one).
So, buying and old 200k insight??? Not for the faint of heart? I am a little worried but, I am pretty mechanical. Think I can handle common problems that pop up on old insights?
02-06-2012, 07:21 PM
home of the odd vehicles
Originally Posted by igo
update:
Everyone likes to talk up the price of old insights but honestly, 10 years old, 200k and bad battery to me = $1500-$3k, if you figure its worth the bank, go for it. Just see if he has any maintenance records.
If the XMSN, clutch and other goodies are all original, me thinks less.
02-06-2012, 11:17 PM
Looking for an Insight
I am thinking about an insight. how do you tell if the battery is in need of replacement? any thoughts?
Thanks,
John
02-07-2012, 12:06 AM
OK, I am a total insight noob but, from what I can tell the cars IMA light will be on if there is problems.
Also, with a few small tweaks you can run the insight fine without the hybrid functions (except less power and worse gas millage). Which is what I will plan on doing at fist if I end up getting that car...maybe later I will try to referb the battery.
02-09-2012, 02:11 AM
#9 (permalink)
5 Gears of Fury
The IMA battery light should come on if there is a traction battery issue, but make sure the IMA light hasn't been disconnected! When I bought my first one I knew nothing about them, and didn't even know there was an IMA light. Needless to say it had been disconnected and the battery pack was toast. When you first turn the key on, all your dash warning lights will self test (ABS, check engine, etc) make sure you see the IMA one too.
They will run fine with a dead traction battery, a little gutless but mine averaged in the low 50s for MPGs, and that was mostly in town driving where the traction battery would have helped out the most.
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
02-09-2012, 01:43 PM
#10 (permalink)
I too was thinking about buying a Honda Insight the newer models, but after researching the Insight and comparing it to the Toyota Prius. I will and recommend buying a Prius. Now before there are any negative comments here are the reason why, the drive train where the electric motor and ICE connect to put power to the wheels. Honda missed it, they have the ICE and electric motor connected together. They are both running at the same time when power is needed to the wheels Honda's Integrated Motor Assist. On the other hand the Prius as a Planetary Gear System. Power to the wheels can be individually provided either by the ICE or electric motor or together. If you are thinking long term I would choose a Prius because the battery packs in the future will be more powerful, you will be able to upgrade the packs, and the Prius would be able to run on electric power for a longer period of time using less fuel. The Insight has to have the ICE on running to power the wheels. I was all about the Insight until I read about the drive train.
