Chrysler aerodynamic "stow 'n' go" roof racks
3 Attachment(s)
Some friends recently got a Chrysler minivan, and I noticed it has pretty clever stowable crossbars:
http://ecomodder.com/forum/attachmen...1&d=1474300962 http://ecomodder.com/forum/attachmen...1&d=1474300962 http://ecomodder.com/forum/attachmen...1&d=1474300961 The bars stow in the rails themselves. And extra clever bonus points: no tools required! I didn't get a side shot, but they rails are fairly low - profile. I also noticed if you wanted to take the rail off completely, the nuts are easily accessible. |
That's neat. Thanks
They are great. Even better then a rack with the bars removed as they are much lower profile when stored. Then they are always there if you do need them. When we got our van used I was thinking there was something missing, I thought maybe the knobs were to remove the rails so it tried but instead found the crossbars.
As an added bonus, they've got slots in the verticals to run a strap through and along the bottom. It's easy to use and solid.
So the rail pivots 90°? Overall shape is square?
If you lay a level or straightedge on it, how much crown side to side? Front to back? My neighbors park a Saturn coupe right outside my window. I notice the bottom of all the windows lies in a plane. (There is a little crown in the hood to hide the wipers) It occurs to me you could cut the top off one and graft it into the roof of a box van or short bus and have a teardrop bubble top. With a sunroof. |
The crossrails are removable and stow in place, embedded in the side rails. They don't add any frontal area when stowed, except maybe the wing nuts.
