EcoModder.com
-   Off-Topic Tech (https://ecomodder.com/forum/off-topic-tech.html)
-   -   Circulating tank block heater maintenance (https://ecomodder.com/forum/showthread.php/circulating-tank-block-heater-maintenance-35962.html)
Daox 12-18-2017 10:19 AM
3 Attachment(s)
I went about flushing the radiator core on my Mirage this weekend, and at the same time I was going to install my Kats 1000W block heater that I had on my Chevy Metro. The heater is absolutely wonderful and warmed up the engine coolant in about a half hour on the Metro.
I grabbed the heater and pulled off the hoses. This is what I found. There were signs that it had been leaking a little, and the clamp was not nearly as tight as it should have been. You really do need to check these clamps and re-tighten them after a week or two because I know I put that sucker on tight. I assume its the heat cycling that does it.
http://ecomodder.com/forum/attachmen...1&d=1513610066
In any case, I took it apart and cleaned it up. This is what is inside for those who wondered. I know I did.
And its all cleaned up and ready to go into the Mirage now.
Frank Lee 12-18-2017 11:54 AM
On a related note, core plug heaters can need maintenance on their cords, on both ends. In the past I have had to shine the tarnish off the contacts on each end of the cord with steel wool; on the engine side I used di-electric grease to keep from having to crawl under there again for that and on the plug-in end I use a bit of WD-40 but one could easily get away with using nothing because access is easy and the steel wool bit takes only seconds.
oil pan 4 12-18-2017 12:22 PM
This is why I make mine out of welded stainless.
