civic ex coupe 96 not good with SGII
Hi guys,
I asked SGII guy if it is compatible with my civic ex 96 coupe. Their answer was no :(. Can someone with the same civic confirm this? So what is the alternative here? I have a limited electrical engineering knowledge, in order to install MPGuino. Maybe a good old vacuum gauge is for me. Thanks, |
It works fine on my 1996 civic. I think the problem is that you're in Australia - does your car have an OBD-II port?
Australia civic coupe was made in US. The engine is D16Y8 which should be an OBD2, but I still need to confirm it.
Which engine is your civic? |
D16y7. It's the non-vtec version. I know of others with the y8 who use the SG successfully, too.
Thanks for the info. I'll ask the SG guy again.
