Old 09-13-2012, 11:20 PM   #1 (permalink)
Talking El Camino to diesel
I have a 1981 El Camino with a 350 motor...block cracked and have been thinking about turning it into diesel....but I need power still since I pull a lot...campers trailers an such. No idea how to go about this or even practicality of it...some one help please?
Old 09-14-2012, 04:03 AM   #2 (permalink)
darcane's Avatar
I think the chassis on those El Caminos are pretty similar to a Buick Regal:
18 to 1
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 09-14-2012, 12:22 PM   #3 (permalink)
scivicblu83's Avatar
experimental - '90 honda crx hf
90 day: 67.81 mpg (US)
here you go, find an old bread truck thats got a gm chassis and use the four cylinder cummins 4bt engine
4bt chevy 1994 z71 - YouTube
Old 09-14-2012, 02:33 PM   #4 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
I'm sure a Duramax would fit...
I'm not coasting, I'm shifting slowly.
Old 09-14-2012, 03:18 PM   #5 (permalink)
f350 4x4 - '99 Ford f350 xl
90 day: 13.52 mpg (US)
those 4bt are real nice but most are rotary injection and they are very noisy i would be on the look out for a 4bd1t from an isuzu npr or a 4bd2t the 2t indirect injection and the 1t is direct injection these engines are quiet compared to the cummins and with an hx 35 and simple injection pump mods will have more than enough power to pull what every you like and give you very very good economy. a good friend of mine has a newer shortbed reg cab chevy lowered getting in the 30's all day mixed driving with a 4bd1t
99 f350, diesel 7.3 auto 4x4 with 1200 rpm triple disk converter, ts perfromance chip, 4" turbo back exhaust, 4:10 gears trucks weight with me in it is 8100# its a work/daily vehicle
Old 09-14-2012, 09:55 PM   #6 (permalink)
Im know very little about motor.....so modding right off the bat is a no go...everyone I mention this to either laughs at me or looks at me like im trying to fly by flapping my arms...anyone think this is a good idea?
Old 09-15-2012, 12:32 AM   #7 (permalink)
XJ Cherokee - '00 Jeep Cherokee Sport
90 day: 12.96 mpg (US)
FoFO - '11 Ford Focus SE
90 day: 36.78 mpg (US)
6.2 mechanical injection N/A or with a small turbo. I've heard when they put the 6.2 infront of a 700R4 on a 2wd pickup, it got 25mpg on the highway.
Old 09-15-2012, 05:07 PM   #8 (permalink)
Why not a gasoline four-banger turbo? It should get better mileage than the 350, and depending on which 350 and what four-banger it could even give you more power.
-soD
Old 09-16-2012, 03:34 PM   #9 (permalink)
5 Gears of Fury
War_Wagon's Avatar
Spunky - '90 Honda Civic CX
90 day: 35.56 mpg (US)
If you are not very mechanically inclined then it may be too big of a project for you to tackle on your own. That said, a 6.2 or 6.5 GM diesel uses the same bellhousing bolt pattern, so you could keep your current transmission. If you found a complete donor vehicle with a 6.2 non-turbo setup, you could migrate all the parts over to make the Camino a diesel. But this is a lot of work, so make sure you are up to it before you get started. You might be better off selling the Camino and using the funds to get an older 6.2 pick up to work on, that way all the heavy work is done already.
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
Old 09-18-2012, 12:37 AM   #10 (permalink)
Cant sell camino...had 9 years...been through too mucb..and I know its a big job.....restoring body now I'll try to post pictures tomorrow
concept, diesel, idea
