EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   civic radiator fan amps (https://ecomodder.com/forum/showthread.php/civic-radiator-fan-amps-19416.html)
WD40 11-08-2011 02:00 PM
Does anyone know how many AMPS a stock civic radiator fan pulls.
I'm looking at getting a Performance Aluminum Fan Shroud Kit from Mishimoto to match my X-Line Performance Aluminum 3 Core Radiator.
The new fan uses 12.25 volts at 5.7 amps = 69 watts.
Hopefully the new one uses less then the stock one to help save gas.
As it is the 3 core rad reduces the amount of time the fan comes on dramatically even with my 95% grill block.
Thanks for any help
Dennis
Thunder 11-13-2011 11:00 PM
Blew a fuse for my head lights one time swapped out the fan fuse with a 5amp one drove it like that ever since hasn’t blown in 2 years. 91 civic 1.5L don’t know if that helps.
j12piprius 04-24-2014 10:28 PM
3 core radiator
WD40, how do you like the 3 core radiator?
Cobb 04-25-2014 06:37 PM
Smaller fans typically use less amps. You could also hook 2 in series and use one as a pusher and puller to reduce power used and move more air.
Water wetter works well too in making the cooling system work better. :thumbup:
