Civic - ? Removing plastic cover cap over injector wires?
Has anyone removed this cover cap, and how?
I found 2 release tabs on the top surface near the rear, and one on the driver's end. Those loosen it some but its still not free. '97 Civic HX: SOHC with VTEC. http://i188.photobucket.com/albums/z...23_small_a.jpg It's for a fuel cut switch. A single wire will run from dash switch to control a new relay in engine bay. Relay will open or close the always hot wire going to the injectors. The injector grounds are switched by the PCM (computer). |
If your talking about the black box, it just has 2 places it snaps together like a pencil box and then you pull the wires out.
I have no idea, but I'm curious. Is it really a 1-wire solution? I may have to do that myself, then.
I haven't done it yet - been busy resolving other issues before participating in the Green Grand Prix coming up this weekend.
BUT - I'm told that the key is (2) 10 mm. hex head screws at the back of it, which I've seen. Those, plus 2 clips I found that accessible thru slots in top top plate, and one clip at driver's side end. Maybe if you're in the UK its on the passenger side but that's a whole different question. I'm told that the clips alone release it, but pulling the screws lets you see what you're doing better. |
