Old 06-29-2012, 08:46 AM   #1 (permalink)
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 Nissan 720 KC 4x4 ST with fiberglass cap
90 day: 21.78 mpg (US)
Elroy - '03 Ford Focus ZX3 w/Zetec DOHC engine
90 day: 32.89 mpg (US)
Device to allow keeping throttle just above idle?
Has anyone designed a simple system where you would add a finely adjustable solenoid at the throttle body to allow keeping the TPS slightly above idle area for use when running at 25-35 mph and for adjusting speed when approaching a stop sign?
This would be controlled by a dashboard switch.
Carry on humans...we are extremely proud of you. ..................
Forty-six percent of Americans believe in the creationist view that God created humans in their present form at one time within the last 10,000 years. GALLUP POLL
Old 06-29-2012, 09:07 AM   #2 (permalink)
Why would you want to keep your rpms above idle?
Old 06-29-2012, 09:20 AM   #3 (permalink)
My Focus idles at 16 TPS...when going 25-35 mph... keeping the TPS at 17-18 results in maintaining speed and seeing the best mpg....same as when approaching a stop sign or corner and trying to get to the sign at 25-30-35 mph. Also this would help when going over some hills.
I currently do this manually...but it is difficult.
These kinds of solenoids have been used on various cars that have AC...to up the idle some....
Old 06-29-2012, 06:47 PM   #4 (permalink)
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
Dfco
are you coasting ?
are you in neutral ... or in gear , automatic trans , 5 speed ?
Old 06-30-2012, 02:58 AM   #5 (permalink)
clank - '99 jeep tj sport
90 day: 17.32 mpg (US)
not too sure about fords; but gm and chrysler both use iac stepper motor's to control idle rpm. 4 wires normally, 2 to control in and 2 to control out; but you'd probably have to disconnect it some how from the pcm to gain control and the pcm might freak out.
Old 06-30-2012, 08:07 AM   #6 (permalink)
Auto...in gear.
The solenoid idea would require custom fitting....another idea would be to use a choke cable to insert a thin shim at the throttle stop.
The Scangauge indicates mpg in the low 40s at 25-35 mph....TPS 17-18.
I use a sort of pulse and glide...TPS at 32-37 to go....glide into stops and corners...in gear. The 18 TPS would be used in 25-35 mph areas and to adjust speed for stops and hills.
Originally Posted by mwebb View Post
are you coasting ?
Old 06-30-2012, 03:02 PM   #7 (permalink)
vskid3's Avatar
Civic DX (sold) - '97 Honda Civic DX
90 day: 34.15 mpg (US)
GTO (sold) - '04 Pontiac GTO
90 day: 22.62 mpg (US)
Green Brick (sold) - '06 Ford Escape Hybrid
90 day: 31.93 mpg (US)
It sounds like a hand throttle would do the job. Pretty much hook something like a bicycle gear shifter to your throttle, which you can then use as a sort of cruise control for the throttle (pretty much what you're saying you do with your foot but easier to hold at a certain TPS). Some offroading guys like to use them, so that's where I would start looking for info and ideas.
Camry Thread
E-Bike Thread
Old 07-01-2012, 07:00 PM   #8 (permalink)
mwebb's Avatar
MJpies or similar
Auto...in gear.
search for the cruise control setup of MJpies or a similar name , he has used the MAP sensor from a FORD (digital signal )instead of VSS input to regulate engine load / speed
his idea / invention will provide what you seek in a much better way than the way you are chasing
