EcoModder.com
-   DIY / How-to (https://ecomodder.com/forum/diy-how.html)
-   -   Civic VX MPGUINO Install with pictures (https://ecomodder.com/forum/showthread.php/civic-vx-mpguino-install-pictures-31847.html)
lilwilly75 04-30-2015 09:00 PM
HOW TO INSTALL AN MPGUINO INTO A HONDA CIVIC 1992 1993 1994 1995
There are four terminations you need to make for your MPGuino:
Injector
VSS
12v (constant)
Ground
1. For the INJECTOR AND VSS: Uncover the ECU which is under the carpet by the passenger door under the dash. To do that loosen the the plastic trim on the bottom of the door and you will be able to pull the carpet back easily.
2. There is 1 nut and 3 bolts that hold the ECU in. Use a 10mm socket and remove all of them. Carefully flip the ECU upside down so the connections are facing you. There are 3 connections, left to right A, B, and D (I know, goofy)
http://i188.photobucket.com/albums/z...5/IMG_5315.jpg
3. INJECTOR: Connector A Pin 1 is the INJECTOR labeled INJ or your MPGuino. I used disconnect terminals so ensure a proper connection. With the right tools these are easy to install. The red I used for the smaller gauge wire coming from the ECU, and the blue I crimped in the wire going to my MPGuino along with the other cut end of the Injector wire
http://i188.photobucket.com/albums/z...5/IMG_5316.jpg
4. VSS: Connector B (the middle connector) Pin 10 is your VSS, same instructions as step 3
http://i188.photobucket.com/albums/z...5/IMG_5317.jpg
http://i188.photobucket.com/albums/z...5/IMG_5318.jpg
http://i188.photobucket.com/albums/z...6628b14c70.jpg
5. I ran the wires under the dash up to my steering column.
FOR THE 12V (CONSTANT)
6. 12V(constant): Move over to the drivers side and locate the fuse panel. Honda has done a marvelous thing and given us EXTRA "outlets" for our accesories. Below is a screen shot of a diagram I found for how these outlets are wired. The two on the left are constant 12v. The second one in is inline with fuse 17, that is what I used. You can use a female disconnect terminal for this connection. I put a 5 amp fuse in 17.
http://i188.photobucket.com/albums/z...e3834c4ee0.jpg
http://i188.photobucket.com/albums/z...5/IMG_5320.jpg
7. GROUND: There are several bolts for frame members under the steering column. If you got this far, I don't think I need to show you those. Take off a nut or bolt and put a ring terminal on it and bolt it back up.
8. I ran my wires under the dash up to the steering column. I drilled a hole in the top steering column cover and attached my MPGUINO enclosure, with two small/short self-tapping screws.
9. Here is the finished product. This was my first install of an MPGUINO, and I'm VERY happy with it. Please pass this along to your friends. I am also editing a video of the same install for Youtube, that I will post soon.
Enjoy, and let me know if you have any questions! FYI, I used the wiki-settings for my VX when I set up the MPGUINO.
http://i188.photobucket.com/albums/z...5/IMG_5323.jpg
92civicvx 05-23-2015 02:09 PM
Awesome write up!!
Joseph Reinhart 05-29-2015 08:56 PM
Help needed: installing MPGuino
I am not getting the MPGuino to turn on???:confused: I twisted and then soldered the wires of the MPGuino to my 18 gauge wire and connected them like lilwilly75 (except I used 18 - 14 weatherproof quick splices ti the ECU & Injector):
I drove the car a little bit but the MPGuino never turned on:(.
Can anyone help me?
The MPGuino wires were 2 to 3 times as small as my 18 gauge wire; could this be a problem?
My car is a 1994 Honda Civic VX :)
God Bless,
Joseph
lilwilly75 05-29-2015 11:29 PM
Joseph, the weatherproof quick wires are ok for some applications in a home where nothing in the wall moves. I do not recommend them for a car. Everything in a car has potential to vibrate which will damage the connection, and also the locations for these connections could get kicked. Anytime you are using this type of splice connection, you are compromising the integrity of the wire. Redo the terminations with male and female connector terminals and if you have the right wires, it should work. Also double check the connections at the MPGuino. Lastly, look for solder splices or damaged components on the Guino.
If you are still having trouble let me know. Did you install the fuse in slot 17 for your constant hot?
Joseph Reinhart 05-30-2015 08:50 PM
Thank you so much for your help! :) I got it to work! :thumbup: The problem was I didn't realize that my ground connection was a false ground :eek:
I'll let you know how the calibration goes ;) as of now I think it's 20 mpg off in the negative; so instead of reading 57 it's reading 37.
God Bless,
Joseph
lilwilly75 06-01-2015 11:26 AM
God Bless,
Joseph
Great! Just follow the calibration on the wiki page, and it will be spot on.
vXcommuter 03-09-2016 12:38 AM
Great write up! Did you ever post the video on YouTube?
