Civic VX O2 Sensor Conumdrum
Okay folks, I'm presently looking for the definitive answer to which type of O2 sensor that I would need to buy to enable lean burn on my 94 Civic Vx. I just recently purchased the vehicle, whereas the NTK O2 sensor that's currently installed is stamped as LZA09-E1. I'm not certain; but I think that this may be the wrong one.
To get right to the point, am I stuck with purchasing the OEM version, or is there a comparable aftermarket sensor that will give me the same result as the factory OEM O2 sensor? If so, who makes it, what's the part number, and where can I find it? Also, it would be great to hear from any member of this forum who can attest to utilizing one. My car is a stock 94 Civic VX Federal, with the D15Z1 engine and 5-wire O2 sensor. Overall, the car runs fine; but my gas mileage has been lousy. Thank You. |
That's the same one I run. Its correct, but may be dying. Here's the listing details:
NGK Partfinder for Cars & Light Commercial Vehicles I'd suggest looking elsewhere for issues. |
I'm presently running in the low 30's, whereas fuel economy has seemed to have dipped in the last two weeks. Tire pressure is even up to 40lbs. Finally, when I pulled the O2 sensor, it looked very black; but so far, I'm not getting a check engine light. |
It's rare for the o2 sensor to throw a check engine light code, unplugging the o2 sensor is the most common way to test it as most people feel a stumbling with a failed o2 sensor.
Bad exhaust or over sized exhaust is the most common caused of a dead o2 sensor. |
I bought one off Rockauto.com and its been working great. I dont remember the brand but after next day rush shipping it was $160ish. Ive never had any issues with it and enter and exit lean burn very smoothly
What kinda mileage on this beast? |
But to put things back on track, I'd like to know what aftermarket O2 sensors would work for when the time comes when I actually need one. I understand that the Bosch 13246 sensor is actually stamped as L1H1. Can anyone confirm this fact? |
I need this answer Too!
Little help? As in is this a correct sensor? |
I bought a Bosch oxygen sensor for my DX. It crapped out after only a few thousand miles - maybe 5 - 8,000 miles.
I then read online about Bosch having some quality issues with their O2 sensors. Just thought I would pass that on, if you are considering an aftermarket part. |
For future reference, whatever you do, don't let anyone talk you into buying a used O2 sensor or the NTK 24542 OXYGEN 5-wire O2 sensor with the blue wire within the configuration. The NTK came with my car when I first bought it and my gas mileage suffered. |
I looked for 2 days for this answer...Thank you.
VX was stumbling in lean mode. Unplug sensor and stumbling went away. Then I put in the new L1H1 Stamped o2 sensor and the car runs very good now. I drove the car stumbling like that for 3 months....I should have unplugged the o2 sensor....I was getting 35-40 mpg on highway. I cannot wait to see what I get now.
