EcoModder.com
-   Off-Topic Tech (https://ecomodder.com/forum/off-topic-tech.html)
-   -   Civic VX oil recommendations (https://ecomodder.com/forum/showthread.php/civic-vx-oil-recommendations-32505.html)
GotToyota 08-05-2015 11:41 AM
What are most of you guys running for engine oil in these cars? With fall/winter right around the corner I am debating switching from 5W-30 and running 0W-20, as I get a good bulk deal for it at work (dealership).
Has anyone else had good success with 0W-20?
Daox 08-05-2015 12:26 PM
I'd stay with whateverW-30. That is what the engine was designed for.
user removed 08-05-2015 04:19 PM
Does it get that cold in Portland? Or do you drive places where it gets that cold (consistently below 0 F). Probably would not hurt unless the pressure at idle was too low or it was running out the tailpipe.
regards
mech
