EcoModder.com
-   General Efficiency Discussion (https://ecomodder.com/forum/general-efficiency-discussion.html)
-   -   Civic VX poor mpgs help (https://ecomodder.com/forum/showthread.php/civic-vx-poor-mpgs-help-36835.html)
freethink 09-14-2018 03:12 AM
Hello, I picked up a 92 civic VX to replace a 94 DX that got totaled. I'm not getting the mileage that I should be. I'm only getting about 44mpg. I was getting 47-48 on the DX, so I think I should be getting even better than that with the VX. I've replaced the plugs, wires, air filter, fuel filter, engine oil, tranny oil, O2 sensor, checked the timing, adjusted the valves, good compression, alignment (the rear has some negative camber due to worn springs). Brakes aren't dragging, tire pressure is a few psi above stock. I can't figure out what I'm missing. Any thoughts?
oil pan 4 09-14-2018 11:35 AM
What kind and size of tires does it have?
freethink 09-14-2018 01:43 PM
It has 175/70/13 on the front, and 155/80/13 on the back with the factory 9lb rims.
California98Civic 09-14-2018 02:23 PM
I ask this first question not to be obnoxious but because I don't know you and the car is very old but new to you and your previous car was not a VX: are you sure you have the complete VX engine, with the VX cams (not EX) and the VX transmission? Dudes swap these parts on VXs sometimes. Intake manifold?
What driving conditions are you in? The VX shines in freeway crusing, but its super tall grearing is not necessarily better than your fifth gen DX in the city.
How did you check the timing? And did you jump the ECU first?
Have felt Lean Burn kick in? I have never felt it, but guys who own the lean burn civics sometimes say they can feel it.
Is a check engine light on for any reason? (It would block lean burn.)
Ecky 09-14-2018 02:29 PM
Having the "wrong" tires on my Insight can easily be worth 15+ mpg in some circumstances.
freethink 09-14-2018 02:37 PM
Yes, it definitely has the Z1 engine, and taller gearing. I can feel the lean burn kicking in and out, and I def notice the taller gearing as well.
Most of the driving I do, is on hilly back roads maybe averaging 50mph. Not a whole lot of stop and go.
I checked the (ignition) timing with a timing light, and the timing was dead on, so no need to jump the connector. I'm pretty sure I checked the (valve timing) belt too, but I'll check it again, just to be sure.
There is a very noticeable step down in power when the lean burn kicks in. When I'm on the highway cruising at 60-75mph, it's probably in lean burn for about 80% the time.
No engine light.
freethink 09-14-2018 02:39 PM
I've run the 175's all around before, which is what the DX has from the factory, and I've also run the 155's all around, but not really any difference in mpgs.
Ecky 09-14-2018 02:59 PM
It isn't the width or aspect ratio, it's the tread compound and pattern. Two different 165/65r14 tires can deliver more than 15mpg difference at the same tire pressure in my car. In some cases the difference can be as large as 40mpg. Make sure you have tires which have a low rolling resistance compound and tread pattern.
California98Civic 09-14-2018 03:32 PM
Ecky has good points. There are no objectively reliable stats available to us little people on LRR, either. So it is a crap-shoot wat you get when you choose.
Have you checked for brake drag or wheel bearig wear? Lift each wheel off the groud and spin it?
freethink 09-14-2018 03:51 PM
I was using the same (Sumic GT) tires (175 -13's) on the DX, so I doubt it's a tire issue. I am running a summer tread pattern, but I'm not even sure they make low rolling resistance tires in 13 inch. Maybe in the future, i'll get some fancy tires, but for the moment I'm just trying to figure out why I can just barely get the EPA MPG rating, when I smashed the EPA rating by 15mpg in my DX. I feel like I should be getting 10 more MPGs with the way I drive.
freethink 09-14-2018 03:56 PM
I'll check that, but when I'm on the slightest incline at a stoplight, and I let off the brake, it starts to roll. Plus I have all new drums, rotors, pads, shoes, and all of the sliders seem to slide properly.
