Civic vx trailer hitch
Been doing a lot of research on this and would like to know what hitch you guys use with civic vxs. I dont want to use the one that bolts in through the spare tire cover, has anyone used the sedan hitch on a hatchback? the sedan one bolts to the frame rails which i would prefer. any suggestions or feedback. Im only going to be hauling 2 bikes with it. was considering a roof rack but would prefer a trailer hitch.
No one has installed a trailer hitch before?
There's probably good reason why Honda/ towbar mfg's designed two separate hitches. Chances are using the wrong one will foul something, even if all the mounting points are there.
This hitch has a tongue weight of 200 lbs. As long as your bike rack and bikes do not exceed 200 lbs then you should be fine :) |
try Trailer Hitches & Vehicle Accessories (800)298-8924 they have good support.
