Classic 1969 Mercury Cougar Restomod
Hi from Southern CA
I own a 1969 Mercury Cougar that has been heavily modified. It's now got a 351w overbored 0.03 so 357w.. Afr 205 aluminum heads a decent cam, aluminum intake, forged internals, internally balanced. An EFI Holley Sniper An Aod has been added It's rated over 500hp.. Not exactly eco friendly. BUT a lot has been done with efficiency in mind... I first recorded my tank to tank mpg at 9.. the latest modifications have brought it to ave 14.. I also have a 2005 Civic so not shooting for moon as it has a few eco upgrades already and the Civic a daily driver... doing ok. I'd like to shoot for 20mpg + on the Cougar which I think is doable while keep it close to looking original. I'll list everything done later as well as projects. Belly pan next on list. Raise thermostat to modern 195 degrees. |
Welcome.
Is it as convertible XR-7? [probably not?] The bellypan could start with sealing up the radiator bulkhead. |
Welcome!
I mention the bulkhead to insure all the air is available to the radiator. If there is sufficient room ahead of the radiator behind the grillework a bellmouth helps more.
So goal's already been achieved... new goal =25mpg
So the big change that made it possible was regearing the rear differential. I was still with the original 2.75 rear end ratio. I had somebody who mentioned to me in another group that this ratio was killing me. I'd say about 90% of the info out there just says that lower #'s equal better gas mileage. This poster had mentioned to me , nope it's making your engine lug.. It has to really work to get to your RPM and it's way below where your engine's rpm efficiency curve. Well he is right. I had spent $1000 getting my rear end differential. The best bang for your buck upgrade and they aren't kidding. It will pay for itself though in gas mileage saving in only a few months. I've got an approx 27% increase in torque with this new rearend. It's a definite jump in power. But I've also got a huge jump in gas mileage as my previous best was 14mpg and now I'm getting almost 22.. (and this is two fillups so not a fluke) So I've got a 500hp 69 Cougar that's been lightened a bit, has an AOD, new rear end and Sniper now getting much closer to modern day fast cars. now to lighten it a bit more. and more tuning the EFI Sniper. |
What differential ratio are you using now?
3.5 now.
I had debated between 3.73 / 3.5 |
