clean EGR= crazy mpg ('02 Insight)
OK, well I have a small update. After doing some research, I decided it would be worthwhile to clean the egr plate.
I have had the car for about a month. and it has ~162K miles on it and i have averaged about 54mpg. not bad, just nowhere near what I was hoping for from a 5 speed 02 insight. ON WITH BUSINESS!!! Here is a step by step guide, if anyone needs it. EGR Plate Removal/Cleaning - With Pics - Insight Central: Honda Insight Forum dear lord. one passage was 100% blocked. the other 2 . 85-95% http://i1339.photobucket.com/albums/...psymwwdcpy.jpg http://i1339.photobucket.com/albums/...psobrnuaql.jpg This was the gasket.. http://i1339.photobucket.com/albums/...psjr1nnpfs.jpg and a nasty PCV Valve... http://i1339.photobucket.com/albums/...psobrnuaql.jpg Well. I am a little embarrassed... I cant believe how bad it got. MUCH better. http://i1339.photobucket.com/albums/...psuwkicdxd.jpg and yes... this the OLD NASTY gasket. http://i1339.photobucket.com/albums/...pszfkpaiwb.jpg http://i1339.photobucket.com/albums/...pshjuanhnr.jpg. Here are the rusults. http://i1339.photobucket.com/albums/...psjr0ojkkm.jpg This is on, a single loop. With a 10-12 mph wind from the south. :turtle: 48-58 mph, ~91F after dark (2am, no traffic) the bright yellow road 289. http://i1339.photobucket.com/albums/...psbkh6uwkf.png |
Usually we advise people not to look for magic bullets for better fuel economy, but looks like you found one. :)
If yours was that blocked, it must have been bucking like crazy when approaching lean burn! That driveability issue, more than anything, was what made me want to clean my EGR stuff when I got my Insight. |
The Insights have recycling the exhaust down to a science for mpg. :turtle:
Nice job and great results. You might even be able to run lower grade fuel, if you do not already.
Lots of EGR is one key component of lean burn, since the exhaust gas is basically an inert gas that allows wider throttle opening without consuming more fuel as long as the egr is distributed equally. Once one passage reaches a point in blockage you get timing retarded to avoid preignition. regards Mech |
Mine is starting to buck, maybe its dirty too.
I'm tempted to ask what the causes the blockage. Do Insights have a reputation for consuming oil? That's a lot of carbon and I'm just wondering what would cause it. The passage on my Saturn is pretty blocked but I have attributed it to the amount of oil it burns past the piston rings and sucks through the PCV system. Thought Hondas were better with these problems... Just wondering if there are ways to keep the passage clean so that it doesn't need constant cleanings to maintain peak performance.
Great info, thanks for posting!
There is a fine line with egr's too hot, and you can cause detonation, too cool, nasty build up and they get clogged. Running a car harder will prevent, and possibly even break down old buildup(Higher exaust gas temps)but running hard is bad for mpg. Babying it like us ecomodders tend to never really heats it up.. good for mpgs, but it gets all gummed up. It is important to take note that my car has 161k miles on it and is likely the first it has ever been cleaned. And if you are considering cleaning yours, I say go for it! It's super easy and it can only help! |
Good info, didn't think about the natural build up so much but I guess after 160k even a little at a time would cause some blockage. I've tried cleaning mine and unfortunately it's not as easy as your's. But at some point I need to focus more attention on finding a way to get the passage clean... it has quite a few bad turns that limit probing it clean with a wire brush or something similar
A SMALLl flat head screwdriver works quite nicely
is yours on the hf? |
Excellent photos!
Cleaning Slambo's EGR maze (at 125K or thereabouts) made a considerable difference, but nowhere near as impressive as your Insight jump. Holy cow that's huge. The trick now is to keep those passages clean. I'm throwing a healthy shot of Marvel Mystery Oil into every tank with the hope that it will help. |
Small amount of steam in the egr passage condensed from the exhaust gasses would have the auto techs working on other things...
please elaborate |
Be carefulwith additives. The K&N air filter oil when overapplied wiped out the oxygen sensor on my Insight at 35k miles, no warranty. I didn't install the K&N, done by the previous owner :rolleyes:.
regards Mech |
I will keep that in mind!
I love k&n filters, but over oiling them has been known to cause problems. For example, the MAF sensors on gm products are especially sensitive to over oiling. |
