Clear Rim Covers
Hi there,
I am working on some mods, and would really like to set up rim / wheel covers for my vehicle. It is newer, and I like the aluminum rims and do not want to cover them up. I am going to just use clear tape if I cannot find an alternative, but would like something more permanent, and eco friendly. Unfortunately the significant other is pressuring me to leave, but if anyone has ideas, pleAse let me know! |
Hmm.
So before I was forced to leave, I just wanted to ask for any input. Searching around on here, I have only found pizza pans and metal. I am usually function WAY over form, but I do like my current appearance, and would like to try to preserve it a bit. I had figured some people had worked out a good alternative solution. I want to do it soon, but the dealer put something slippery on my rims that makes them shiny, so I think I will wait until I empty the tank. Hopefully this doesn't just waste a thread, if anyone has any input :) |
to me it reads like..
even if you were able to attach a piece of glass, the reflection at most angles would drastically alter the appearance, and the inside would get covered with dirt and brake dust. |
ok plexiglass
what i was tring to say was even the best clear cover would have a significant impact on the appearance of your wheels anyway |
I really like Polycarbonate. I worked in a glass shop for a while and would not put glass on the outside of a car. Poly(Lexan) brand name is very flexible and very strong but is more expensive than glass or acrylic(plexi) of similar thickness.
Have either of you guys tried these?
My first thought to preserve the looks as much as possible was to install clear plastic panels between the spokes and flush to the surface, but unfortunately looking at the 2012 stock wheels it looks like you'd end up with a concave surface... thinking that's not a good aero idea
Vekke has used polycarbonate transparent hubcaps on his VW for a while They're green translucent though, his Tuneko commercial site has a good pic of clear ones and their effect on the look of the wheel. http://tuneko.com/images/Electric_Ra...ng_hubcaps.jpg Link |
