Climbing a mountain
Ever since having needed to commute daily to work last month, I've been inspired to start hypermiling.
It may not be very impressive, but I took as much from the tips as I could on the recent trip from Orange County to Yosemite. Trip: 3 days 1585km/ 985 miles and only I could drive. Toyota Yaris auto (rental car) Highway Rating: 36 mpg (6.53 L/100km) Actual: 46.85 mpg (5.02 L/100km) On the way back, I found this tour bus which was a godsend: he was doing 70 mph and extremely steady, hardly braking on the downhill sections (on the I-5 S)... I drafted 1 sec behind him for an entire 120 miles. Some suggestions needed: I couldn't do pulse and glide as the terrain was very uneven...and I'm loathe to turn off the engine while gliding. So the best I could do on the downhills was engine break in D...downshifting occasionally to 3 or 2 to not spin off the roads. (anyone have suggestions for more efficient ways)? Also, is it worth spending gas to pass a car if they are constantly braking unnecessarily and wasting momentum on the windy downhills? On the downhill, I take 25 rated corners at 45, 30 at 50, (+20 etc)... Thanks! |
One suggestion; do not break the engine. That is costly and inconvenient.
It had 30000 miles on it, so it had already been broken in. |
From dictionary.com:
Break: to shatter, burst, or become broken; separate into parts or fragments, especially suddenly and violently: The glass broke on the floor. Brake: to slow or stop by means of or as if by means of a brake. |
Yosemite is nice. -mort |
meisterjohnny, your original post raises a few red flags. One second following distance/time is ~102 ft @ 70 mph, way too close to be safe, since the 90% confidence level for reaction time is 2.5 seconds.
You shouldn't even be thinking of engine-off coasting with a Toyota automatic transmission, unless you're prepared to buy a new transmission for your rental car. 70 mph is too fast for hypermiling. 50 mph is safer and more productive. |
I have read comments on here about the very many reasons to not draft so closely, reaction time, road debris, etc.
Personally, I try to stick to 55 MPH. Sometimes, it is even the speed limit! However, with my Ultragauge, when I was accelerating on the freeway, I realized that when I accelerate to 70 MPH, my instant MPG goes from 13-19, so at the moment when I shift to neutral, I am achieving city MPG, which is lousy, but I get pretty good mileage coasting 70-50, although I would not argue that it was worth the effort over staying at a steady 55. I highly recommend Driving with Load. Cruise control is great for level ground, but in an automatic, my transmission downshifts with the slightest incline, and higher revolutions and lower gear are a terrible combination for mileage. I accelerate just hard enough to not downshift, even though I lose some speed. I pass people if I am stuck behind them for a while and they are driving erratically. I had a van cut me off on my last trip. They seemed to fly over hills, but they kept braking around curves, so I coasted past. I just hate being around people who do not seem to keep a constant speed or have any predictability. One of the problems is that if you manage to rid yourself of one idiot, sooner or later you will run into another. |
So 2 lane highway trips, always bugged me, then I discovered that if I travel 5mph under I don't come upon so many erratic drivers, vs driving the speed limit. The other benifit is I better economy to.
