Coal
Re: Post #10
There are lots of ways to classify coal. It has been intensely studied since the eighteenth century. Coal will probably always be needed for making steel. |
More than Anthracite/Bituminous? Anthracite is 'clean coal'. Bituminous is closer to peat.
K?
Too busy to mention it this morning but the new kid on the block is electric smelting
Cast iron has lots of impurities relative to steel. Once it is molten, by any process you choose, you remove all the impurities through chemical absorption or oxidation. Bessemer used air jets through the kettle and scraped off the slag.
Then you put the materials back in in the proportion you need. Not rocket science. |
Most of the Brazilian coal, usually located in Santa Catarina and my home state Rio Grande do Sul, is of a low quality with a lot of sulphur contamination, just like the coal which exploded aboard the Titanic leading to a fire that weakened a section of the hull, leading to the sheetmetal being shredded at the impact with the iceberg. So, most of the Brazilian steel mills operate with coal imported from South Africa, while local coal is mostly used as a fuel for powerplants.
