Coast in-neutral vs in-gear: I've been challenged to show the numbers
... which I thought would be easy to do by searching this forum. Well, it's turned out to be easier said than done. I've been through several threads where I expected to find the numbers to back up the logical conclusion that coasting in neutral loses less momentum and therefore results in lower fuel use. However, nobody seems to have done an A-B-A comparison, much to my surprise. The closest I've found is this post:
http://ecomodder.com/forum/showthrea...html#post41066 But he didn't do full tank comparisons of the techniques, which is what I think will be the best (only) way to convince the doubters. Has anyone done such a test and can post the results? I know that the idea, once correctly explained, is so logical that testing it seems absurd, but some people take quite a bit of convincing. |
Why bother, it would be like convincing someone fire engines are red. Its obvious.
It's hardly possible to get decent numbers in normal driving, as you can't even start measuring from the spot where the coasting starts.
It'd have to be measured between a spot where one enters with X mph, and a place where one has to turn off at Y mph - that'd have to be reachable by coasting. I started coasting shortly after joining ecomodder. Coasting (even in neutral with the engine on) is what got me consistently below 5L/100km / over 47 mpg. Up to then, I was avidly using engine braking, and only once in 5 years got below 5L/100km / over 47 mpg. People are easily misled by the fact that their engine doesn't use gas when decelerating and letting of the gas pedal. They don't realize they are also going to stop far, far sooner |
I think what my challenger is after is more of a net mpg gain as measured at fuel-up time. Not the instantaneous mpg or gph during the coast. But after thinking about it, this would be hard to accomplish wouldn't it. There would need to be a test route that allows coasting and that is long enough to allow a measurable amount of gas to be pumped at the end of it.
The conditions would need to be similar for each test, which would be something like: 1. Fill the tank 2. Drive the route using in-gear coasting 3. Refill the tank and record data 4. Drive the route using in-neutral coasting 5. Repeat 3 6. Repeat 2 and 3. Yes, I can see why nobody has done this. |
Let your challenger try it ;)
Nothing more convincing than first hand experience. I too was reluctant to try it, but it works. Despite the overshoots, even the first tries will yield results. It will only get better when he gets more experience with coasting - i.e. ever more appropriate starting point / speed and thus better matching the coast to the desired speed at the next waypoint. |
I did an AB test with this on 2 separate tanks it was roughly the same temperatures and traffic, and the same route the whole time. Coasting in Neutral resulted 23mpgs while coasting in gear resulted 20mpgs, even if by chance the cars do coast the same in neutral as in gear which i feel neutral coasts further your rpms drop in neutral resulting in better mpgs.
Coasting in gear is not really coasting, since there is engine braking involved unless clutch disengaged in a manual). You can get hundreds of MPG coasting in neutral but if you are using engine braking you can engage DFCO and get infinite mileage for a shorter distance. Ideally you should be able to coast in neutral to a complete stop for the best theoretical mileage, but it just doesn't happen to most people in typical traffic.
I coast in neutral when it will not aggravate other drivers, then use engine braking when I need to slow down more rapidly. regards Mech |
Thanks, but I've seen this reasoning hundreds of times in all the prior threads on the topic. And very convincing it is ... to me at least. It hasn't been until gealii's post that I've seen someone back up the reasoning with real numbers. You're all probably right that those numbers won't convince my challenger, but I do believe that you people have risen to the challenge. Thank you.
I have been getting better gas mileage using DFCO in gear coasting with a pulse and glide technique. Better than what I was getting with engine running coasting pulse and glide. EOC is by far the best, but there are very few places n my commute where this would make sense.
Been messing with the Cobalt using engine braking, it goes open loop and gph goes from 0.31 at idle (ac off) to over 0.5 after releasing clutch with heavy engine braking, takes 5+ seconds for it to go DFFO if it does and then doesn't stay in it for long. Neutral coasting is way better, the factory gauge is only 2 digits, so wouldn't have known the difference without the SGII.
Edit: Paid a little more attention on the way home, if I crest a hill and leave it in 5th, after about 5 secons it goes Open loop, and up to 0.4 gph for about 5 more seconds, then goes into DFCO for about 5 more seconds (smallish Iowa hill, maybe 3% grade, 100' fall) then back to closed loop. Pretty sure Neutral Coasting would account for better FE. |
If someone is going to compaire the 2 techniques then they also need to change the driving style...example: if you start to coast in neutral at the same point of the road where you would when in gear then you are actualy using more fuel, so in order to use less fuel you can, and need to start coasting in neutral earlier than you would when in gear...
Its hard to explain but im just trying to create a scenario where someone is aproaching a stop sign or a red light |
I hope that person who said all fire trucks are red was joking.
That's not a constant, lol. Honestly, very little is constant. The sky is always blue- what about a sunset or sunrise? Gravity is always the same- it changes with elevation and location. So maybe there vehicle, combined with their location, their traffic, driving style, and gerneral commute yield better results with that method. I think it could be possible. I pulse and glidw from 74mph to 65mph, so I don't block traffic, and I only get to that speed by drafting. I was just thinking about taking a super compact car, say old Civic and putting a huge engine in, with at least a six speed, if the engine can run at very low rpms and maintain speed. I can often get 35-40mpg on my commute, but I stop at a light then I drop .1 rpm about every 5 seconds. I don't know if I am clear, but my basic point is for ones own unique circumstances, it may be possible. But your point does appear to be more probable, if you use X fuel to get to a speed, and have Y friction, you travel a distance. If Y increase, auch as engine drag, over that limited area, mpg SHOULD be lower. EDIT: http://my.firefighternation.com/grou...age=2#comments |
I hope you're joking. The OP was asked to "prove" that coasting in neutral is more efficient than engine braking. If reb01501's challenger wanted data specific to his car and terrain then he shouldn't have asked someone to check the internet for data.
I've seen fire trucks in yellow, brown and woodland camo, but if my kid asks me what color fire trucks are I wouldn't say "it depends." |
I see, about your child. I don't have any children, but I'd say usually they are red, but you can paint it any color. |
Not "prove" ... provide evidence to back up the assertion. There is a difference. I in no way believe that a few test result will provide absolute proof of the assertion. All it takes is one contrary result to disprove it. However, the lack of negative results is telling.
You have to be on the gas longer to reach a coast point too. You lose on both ends when you coast in gear. |
Most people start coasting before coming to a stop, in that situation in gear will only be beneficial (engine doesn't need fuel to idle, free braking from the engine, etc).
Hypermiling is an entirely different ballpark so complaining that one is better then the other is apples and oranges. It also matters between cars and a lot of things. Everyone argueing its "obvious" what the solution is is being shortsighted and ignorant. Test it and post your test conditions, your car, and your results. |
Automatics tranny engine braking depends on the car. Neither of my GM auto coast hardly any different OD or N. If engine braking is wanted need to put them in D or 2. Stratus engine brakes and downshift and brakes even more, so it needs to be shifted to N to coast well.
I wonder if the CRV is it keeping it's torque convertor locked going down hill to avoid speeding up. But unlocks it when coasting as long as not gaining speed. The stratus if cruise is set and go down a hill large enough for it to pickup speed, will disconnect the tranny, the engine revs to 3,000 rpm, waiting for the car to get back down to the set point where the tranny will reengage, on hills that I know it will do it I will cancel cruise, shift to N, and then reengage tranny & cruise once the coast if over. |
So for me, in THIS case, in gear coasting is very beneficial. Or maybe it's not technically coasting since I start at a stop. If this is the highway we are talking, then hands down, I totally agree. But unless I am 30+ mph, going uphill, or can see my stop point, I (think) I am better off in gear. But those are strict standards. So I can happily agree usually out of gear coasting is more efficient than in gear. |
Coast down a secluded hill from a set starting point, till you reach a stop,mark the spot. Repeat it in neutral , repeat it all again. Then crunch the numbers.
UltArc- Sorry, I wasn't trying to get in your face too much. But I was really hoping that you were joking in your hope that ksa8907 was joking.
To the challenge of "Find me some numbers," The only real answer here is "I can't." It can't realistically be tested for. The sheer obvoiusness of riding the brakes being bad for FE really turns the question around: Don't ask me to explain the benefits of coasting in neutral, explain to me why you think staying in gear is better than popping it into neutral. |
Coast in neutral, at 70 MPH, down a 5% grade on the Interstate (in neutral which is the DEFINITION of coasting) with a tractor trailer on yer butt, then shove it in gear and see what happens.
regards Mech |
I see your point in that, but some people are not very open minded :/ They get an idea, and that is just so until proven otherwise. My family is very much stubborn in this way. For years I have been telling them to unplug chargers and tvs and whatever they don't use, as it drains power. They finally did it to shut me up, and now they must constantly unplug everything that is not theirs, because of the energy they save. Even on here, I remember someone switched to a funnel air intake rather than stock on a Focus I believe, and did not do very scientific reporting. The response was not very friendly lol. I know now to watch my exhuast when I talk about FE numbers lol. |
There is no question that coasting in gear loses less gas DURING the coast than coasting in neutral ... |
When in gear the motor / transmission become a brake if gas is not applied. Driving around with slight engine braking will lower your coast speed and length, meaning you will need to apply the throttle sooner then if you had it in neutral. I have a sneaking suspicion that a car while in neutral and idling at 800 rpm is going to use less gas then a car engine braking at 3000 or more rpm. these are the reasons i coast in neutral. |
I have my preconceptions so a test would be cool. I think people could expect at least a 10% improvement by using neutral over Drive, i will add i use neutral constantly in my driving. |
Hi, folks!
For what it's worth... I've been driving my Honda for a bit more than a year now. A while back, I started using neutral for coasting while driving in town. Three tanks ago, I decided to start using neutral for coasting downhill on the highway. I cruise at 57 MPH, and usually I'm able to maintain that speed during my neutral coasts. I had been unable to maintain that speed when "coasting" in gear and used a lot more gas. The evidence is in my fuel log (click the Honda badge in my signature). My last three tanks have been my three best tanks, averaging 47.01 MPG. The three tanks prior to those averaged 42.78 MPG. -Doug "Whitey" Jackson |
On the way home tonight with Cobalt I did a quick ABA, long gentle hill, about 120 mpg 5the gear 55 mph, was slowing 1 mph per 2 seconds or so, so best guess within 10 mpg. Accellerated back to 55 mph, neutral coast 170 mpg, just steep enough to maintain speed so a pretty good number. Back to 5th gear 55 mph again pretty much 120 mpg. I haven't calibrated my SGII for this car yet, still on first tank, but comparing factory gauge to SGII it's in the ball park.
So roughly (160/120) 1/3 less fuel is used coasting with my car, plus it holds speed longer so coast could be started sooner so even more is really saved. DFCO doesn't really seem effective with the little bit I've played with it in the Cobalt. Even with aggressive down shifting for braking, fuel consumption actually goes up initially, only after atleast 2-3 seconds often 5 or more if it does at all will it go into DFCO. With my Cobalt I need to resist using engine braking as it's wasteful. |
Tell me how you suggest one measure for results? |
Those were fast tests from you two guys, they confirm what i posted, thanks for the favorable results :-) |
here is that botched article from PM online.
All the same tomorrow i am going to test my car by coasting with the ignition off in gear then switch on the ignition and listen/feel for any change,like wise by testing with the ignition on in gear then switching it off. Bust this myth, one way or the other. I think the "Scangauge" reads injector pulse durations and has a function to read them,it would be useful to bust this Myth. if anyone has one, take some readings while coasting in gear, engine on, its somewhere in the Scangauges menu. No need to test with engine off as it will most definitely not be injecting any fuel. the Article, finally ! Tactic No. 6: When Coasting Downhill, Leave the Car in Gear There are those who refuse to be shaken from the practice of coasting downhill in neutral to save gas. This is a bad idea no matter how you look at it. Let's set aside fuel economy for a moment. Coasting downhill in neutral is illegal in most states. And it's dangerous in all states. In neutral, you have no way to accelerate to avoid a hazard, and if the engine stalls, you have no power steering or vacuum boost for the brakes. If the hill is steep enough to call for hitting the brakes to keep you from gaining speed, they're more likely to overheat—and overheated brakes lose effectiveness until they cool off. They'll probably do that right around the time the police show up to take the accident report. Here's the surprise: There's no tradeoff between safety and fuel economy in this case. Leaving the car in gear while coasting downhill actually is more efficient. Why? Most fuel-injected engines today use computer-controlled Deceleration Fuel Cut Off: When you lift your foot from the gas while leaving the car in gear, injectors shut off automatically, and the car's rotating tires—which are connected to the engine via the transmission—keep the engine turning and the accessories running. So, the engine consumes no fuel at all while the vehicle is coasting downhill. In contrast, the fuel-consumption rate for an engine idling in neutral falls between 0.2 and 0.4 gallons per hour (gph). Splitting the difference and using 0.3 gph for our example, idling in neutral down a ½-mile-long hill consumes fuel for 30 seconds, for a total of about 0.32 ounces of gas. Popping the car into neutral actually wastes gas. This may seem counterintuitive, but that's what data are for—replacing good guesses with solid facts. Watch the data, and over time the savings will take care of itself. Read more: Driving Tips to Save Gas - Memorial Day Weekend - Popular Mechanics Driving Tips to Save Gas - Memorial Day Weekend - Popular Mechanics |
