Old 07-20-2011, 09:41 PM   #1 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
New to EOC.
I've just recently started working on EOC. It's already given me a huge jump from 28-9 mpg tanks to 31-2 mpg tanks. Where hypermiling has made the near mythical LGT 400 mile tank a given, hypermiling with EOC has put me in a good position to get regular 500 mile tanks.
So I'm a little over halfway through my fourth tank using EOC and I'm noticing new things and running through beginner learning experiences. To date:
-I've got to work out that kill switch. It would make shutting off a whole lot smoother, I wouldn't lose "credit" for the distance traveled while the key is off and I wouldn't have to wait for Torque to get back in touch with the ECU. I hate being without that load gauge.
-Torque maxes out at 255 mpg for its instant readout.
-In my car, bump starting in fifth gear above 10 mph is no problem.
-Bump starting in first gear is bad.
-Not having power brakes is horrible if you:
1) aren't paying attention to the world around you
2) don't know how to drive
3) panic
The third time I hit my brakes in a glide this morning, nothing happened, but with a quick bump start the problem was over. Now I need to familiarize myself with non-power brakes.
-Driving along without the engine running is one of the most thoroughly amusing things I've ever done.
So, what other litle tidbits am I going to come across in the near future?
Transmission type Efficiency
Old 07-20-2011, 10:53 PM   #2 (permalink)
MPG Militia HMV-25E80+A
JethroBodine's Avatar
FrankenJetta D - '90 Volkswagen Jetta GL
Diesel
90 day: 64.35 mpg (US)
For me it is about trying new stratagies and reprogramming myself to use the techniques here to their best advantage. I do know that once I started dropping my coast-to speed and using a lower gear(say 3rd instead of 5th for 40-25 mph P&G) my mileage bumped up a good bit. Also, if there is no traffic behind you, it's AMAZING how far you go at 25mph. I'm still learning as well and what I've come up with is; know your car, know your route, and know yourself. If your car likes accelerating at 70% load more than 80%, use it. Find your routes best oppertunities for differant techniques. No two corners/hills/flats are exactly the same. And last, know how good/bad of a driver you are and what you can get out of your machine. Kill switches are wonderful, and I agree, coasting is the closest thing you can get to being a kid again.
YMMV
It is always very amusing how our imagination is put to the test when overcoming reality. Redyaris
Boat tail project
How to gently bump start during EOC
Old 07-21-2011, 10:22 AM   #3 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
Slower is better for mpg. I used to P&G in 4th gear from 25-40 mph. 8 seconds pulse, 24 second glide, 55-60 mpg. Dropped it to 3rd gear from 20-30 mph, and the P:G ratio is about 7 seconds pulse, 40 seconds glide, 60-70 mpg. Just for kicks, I tried 10 miles of 2nd gear P&G (10-20 mph). That's about 3 seconds pulse, 30 seconds glide, and 94.5 mpg! 5th gear highway P&G from 50-60 mph is about 9 seconds pulse, 16 seconds glide, and 45-50 mpg. YMMV with a different engine, tranny, car, etc., but the idea's the same. Your pulse:glide ratio determines your mpg. The more you glide in relation to running the engine, the better your mpg.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 07-21-2011, 12:24 PM   #4 (permalink)
in tents
dennyt's Avatar
The Adventure Wagon - '94 Subaru Loyale Wagon 4x4
Subaru
90 day: 33.43 mpg (US)
Electro-Monkey - '11 Surly Karate Monkey BMC V2S Front Hub Motor
90 day: 694.1 mpg (US)
Bump-starting in a corner is interesting if you have power steering. When the power steering pump starts back up, the steering wheel force required to hold a turn decreases, which you have to anticipate or deal with.
I dealt with it by pulling the PS pump and draining the rack
