Coasting in gear question
Apparently I'm not getting this whole coasting in gear thing, and the engine isn't using fuel. Someone explain this to me. If you coast in gear, the engine isn't using fuel, but you don't coast as far. That's the theory right. Does this apply to all newer cars? If so define 'newer'. Also, at what point does the engine being using fuel again, when you push the accelerator or the brake? Someone help me out.
Most of the cars that do that start using fuel again when the rpms reach somewhere near the normal idle rpm. The only times you should use DFCO is if you have mis-judged the distance to the stop light and are coming in too hot or if you are going down a hill that is long enough to build up too much speed. In the case of the hill, you may even have to start downshifting.
I'd have to say pretty much all OBDII cars have DFCO (decelleration fuel cutoff). The engine will begin using fuel again if you press the gas pedal, shift to neutral, or drop your rpms below the idle speed as Larry said. He is also right in saying it should really only be used when you've misjudged a coasting distance, or you know you need to stop.
Ok. But is this the case with all newer cars? If not what should I look for to tell if my car's engine will shut off if I take my foot off the gas?
You can tell very easily with a scangauge!
If you don't have one (and you should) you can tell by coasting down in gear. Let the RPMs drop below idle speed. You should be able to feel the engine try to keep itself at idle rpms. |
I don't have a scangauge. Is this the only way to tell, by feeling if the engine is trying to keep itself at idle rpms?
Well with a manual, one test I heard about it is getting up to like 20 mph and taking your foot off the gas. Note how the car starts to slow down. Now "shut down" the engine with your key (still in gear, still moving). If you keep slowing down at a similar rate, you have DFCO. If it suddenly starts jerking to a stop...you don't. Be safe trying this if you do.
If I am engine breaking from a decent distance (but not far enough to simply coast in) I usually downshift at about 1500RPM because I believe at 1400RPM my engine starts getting fuel again. |
I know some recent (5 years old) Hyundais don't do DFCO, but those are the only ones I'm aware of. My 1996 Honda does DFCO.
Your THM-4T65E transmission is a four speed auto with a lock-up torque converter clutch (TCC) that works on 2nd, 3rd and 4th gears. When you lift your foot at speed, the engine is driven by the rear wheels and the control unit shuts off the injector pump. See:
4T65E Transmission Info This is a very reliable and mileage-efficient transmission. However, like ALL automatics, you can damage this transmission by coasting in neutral, regardless of whether the engine is off or on, because it is lubricated by a front engine-driven pump that requires higher engine rpms at speed. Therefore if you coast at speed in neutral at idle, the pump will not be receiving sufficient rpms from the engine to properly lubricate the transmission. I know you didn't say you were coasting in neutral, but I have noticed that some people on other threads were confused by this subject so I thought I should mention it. |
would my 93 civic dx 5spd have DFCO?
If you have have an OBD-I car, you need the appropriate Select Monitor to see for sure.
If you have a straight through or loud exhaust you can usually tell, the burble of the engine changes when the injectors are off or on. I am under the impression that maybe besides some rare cars, that most should have some sort of fuel cut-off on deceleration. I have a SPFI engine in a 1989 Subaru GL that does the fuel cut off. In Subarus the fuel cut-off stops around 1750-2000 rpm from what I have seen. But even then, it is using less injector pulse width than in neutral. YMMV. |
While decelerating in gear (lets say ~2500rpm), turn the ignition off. If you feel the car instantly slow down faster, that could indicate that you're not getting a full cutoff. On my car, the SG reads that .3gph are being injected while engine braking... But, with the engine off and ignition on, it also reads .3gph... BUT, while engine braking, I don't get any additional stopping force when I kill the ignition AND I feel the point at which fuel is reintroduced ~1400rpm in 5th. So, I know there's some fuel cut off - but I don't know if it's 100% or not. Alternatively, you could tap into the one of the fuel injector wires and measure :thumbup: |
